Question about Olympus Camedia E-20N Digital Camera
Household type connector
I do not have a household type connector on my studio flash system sync cord, what can I do?
    Master:
  • 852 Answers
You will need to purchase a sync cord that will separate apart (usually at the middle) with a standard two-prong connector. Just simply disconnect the sync cord, turn it 180 ° and plug it in. (These cords can be purchased at www.paramountcords.com)
Posted on Aug 31, 2005
DIY Wire diagram for floor lamp
yes replace cord with new one without switches
Aug 31, 2017 | Dryers
Will sunpak 622 flash work with Nikon 5200?
You will need a "Hot shoe to PC connection adapter" to connect the PC sync cord to your camera
Dot Line Nikon Hot Shoe to PC Connection Adapter
Jan 29, 2014 | Sunpak 622 Super Pro TTL Flash
Can I turn off the automatic slave flash?
plug a cord into the back and do not connect that cord to anything. That with deactivate the slave
Oct 20, 2012 | Promaster Systempro 160a Studio Flash
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
How do I remove an attachment to chuck of black & decker household drill with cord
There is an 2 types of chuck ether it is an screw type or not..If your drill chuck is an screw type it is easy to remove if it is not you must have a special tools to remove it.
Jul 23, 2011 | Decker BlackN Household Drills and Kits...
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Apr 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Is a Hampton Bay HBD240A window A/C 120v or 240v?
I have never seen a 240-volt window A/C unit for the U.S. market. So, my guess is it's 120 volt.
The best way to verify this is to read the name-plate on the unit.
Another way is to look at the plug on the unit's cord. There are at least three types of plugs :: 120 volt, 15 amp; 120 volt 20 amp; and 220 volt. 120 volt 15-amp will fit a standard household wall outlet. The 120 volt 20 amp plug is similar to a 120 volt 15 amp, but will not plug inot a standard household outlet. The 220 volt plug is altoghether different.
Charlie
Jan 08, 2011 | Heating & Cooling
Does the DiMAGE A1 support any external flash including studio light?
Yes, it does. It is usable with any external flash using sync cord to sync terminal. (sync voltage: below 400V, correspond to antipolarity)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Studio Strobe not firing with Coolpix
The Coolpix line of cameras require a "tip positive" sync connection to an external strobe unit (when using the Nikon AS-15 Flash Sync Adapter). On some external Studio Strobe units the sync polarity is easy to change because of the type of plug: On this type of connector simply turn the plug around and insert it with the male pin connectors in the other holes. Other types of connectors (such as the standard "phono" plug) are not generally changeable by the user. If the Coolpix does not fire an external strobe check with the strobe manufacturer for sync polarity info.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Olympus Camedia E-20N Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
