Question about Hitachi Cameras
DIGITAL CAMERAS HDC571 i WAS GIVEN THIS FOR CHRISTMAS 07 AND PRIOR TO THIS WEEK HAVE USED IT ONCE BEFORE. tHE BATTERIES SUPPLIED RAN OUT SHOWED NO POWER ON THE SCREEN SO I HAVE REPLACED THEM. i HAVE SICE TURNED ON THE CAMERA IT THEN INSTANTLY TURNED ITSELF STRAIGHT OFF AND WOULD NOT COME BACK ON. ATFER SOME TIME IT CAME BACK ONAND I TURNED IT OFF BUT NOW WHEN IT TUN IT ON ALL IT DOES IS FLASH ON AND OFF AUTUMATICALLY.
The camera uses a TFTLCD monitor, which is a high power usage device, any battery that are not high power will have the same results as you do (I have the same camera and done the same with cheaper batterys).
I will say go to a supermarket as mostr do Duracell turbo/ultras on 2for1 offers or 8 battery packs at half price.
Posted on Sep 28, 2008
My go pro hero 3 wont switch on, wont charge and shows no red light. basically does nothing. was working 4 days ago but seemed to have short battery life. the camera is only 3 weeks old! Could it just be...
I have the exact same problem. I was able to charge the battery twice, but both times it ran empty after 20-30 min., and now the camera is dead as a brick. Absolutely nothing happens when I try to charge or turn it on. :(
Three weeks old Hero 3 Silver.
Jan 14, 2013 | GoPro Digital Hero 3 Digital Camera
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
Apr 25, 2017 | Nikon CoolPix S4150
My camera shows a "lens error" message
Hello and welcome
The most common cause for a Lens error:
Misaligned Lens rings
Sand and grid wedged in between the lens and the barrel.
Dropping the camera
Ran down battery
The following solutions are there by which you may Fix the lens error
  • Firstly you can try removing the batteries and replacing it with a new set of fully charge ones
  • If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed
  • Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in
  • Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit
  • Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to out the particles
For more solution by which Lens error can Recover Here you Go. It will help you out more briefly
I hope this solution will helpful for u Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 02, 2011 | Nikon Coolpix S4000 Digital Camera
My daughter received the ViviCam 8025 as a Christmas gift but there was no battery in the packaging. Vivitar has offerred to send me a battery but it will take 3-4 weeks for it to get here & I can't...
It uses a Rayovac 5100LB or equivalent, also used by a number of cell phones. Try looking among cell phone batteries.
One source is
http://www.batteriesplus.com/product/38111-RAYNO5100LB-Battery/551-0/5315-Digital-Camera-Batteries/405103-Vivitar/ViviCam-8025.aspx
Jan 06, 2011 | Vivitar ViviCam 8025 Digital Camera
Nikon D90 battery reset
Seems as if you've killed the battery. You might try charging it again.
Does the camera work with a different battery? If so, I'd just buy a new battery and toss the old one.
Jun 26, 2009 | Nikon D90 Digital Camera with 18-105mm...
Sony DSC-H7 won't work!!!!!!!!!!!!
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
The camera is a digital Polaroid i834 . It locked up the power. I have tried new batteries and did not work.It was purchased 11-5-07 for a christmas gift.Cannot turn on and the zoom lens is halfway out.
http://www.polaroid.com/service/userguides/digital/cameras/i834_ug_en.pdf
This link is the user's manual for your camera
There is no response from the
camera while pressing any
buttons.
Remove and re-install the battery
or batteries to reset the camera.
Your valuable data stored in the
camera will not be lost
Polaroid Digital Camera Support
USA / Canada: 1- 877 - 388 - 3779
Hours (EST): Mon-Fri 10am - 7pm, Sat 10am-4pm
That is the best I can do for you. Sorry if this is not enough information.
Good luck.
Mar 27, 2008 | Cameras
Warranty Return
You will have to do this at their site
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
circuit city does not provide a manufactures warranty.
Jan 06, 2008 | Olympus Camedia C-350 Digital Camera
Power supply
You can download the manual from the link below: http://downloadcenter.samsung.com/content/UM/200703/20070330162556328_DigimaxS500_S600_ENG.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
73 people viewed this question
Top Hitachi Cameras Experts
Parshiv Luthra
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
