Question about Canon PowerShot SD200 / IXUS 30 Digital Camera
Error 50 I am getting the error 50 code what should I do?
    Sergeant:
  • 255 Answers
The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
Posted on Aug 31, 2005
3 Suggested Answers
Fishi
  • 255 Answers
SOURCE: Error 50
Posted on Aug 29, 2005
Fishi
  • 255 Answers
SOURCE: Error 50
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
How to fix error code 50 on EFX 5.21i?
Precor Error 50, Too Much Brake (Magnet) Current Probable Cause 1. Shorted or damaged wiring between the lower PCA and the eddy current magnet is the most common cause for this error.
2. Bad eddy current magnet.
3. Bad lower PCA.
Corrective Action
  1. Thoroughly inspect the eddy current wiring and connections ensuring that the wires are not shorted to the frame or shorted together. Repair or replace damaged wiring as necessary.
  2. Disconnect the wires from the eddy current magnet. Using an ohm meter, check for approximately 100 ohms across the eddy current magnet terminals. If the reading is considerably low, replace the eddy current magnet. Measure ohms between each eddy current magnet terminal and the frame ground. You should have no resistance between the eddy current magnet terminal and the frame ground. If resistance is present this would indicate a partial short, replace the eddy current magnet.
  3. If the eddy current magnet wiring and the eddy current magnet are both good from the above tests, replace the lower PCA.
Error 50 Too Much Brake Current on Precor Cardio Equipment
May 22, 2014 | Precor Exercise & Fitness
Brother error code dcp-j 125 unable to Init 50
hi good day! the printer is error 50 due to a paper or some sensor error.. open the printer, or dismantle, clean the sensor and wash the pump of water and change the waste pad of new absorber. locate the sensor under the pump, clean it of alcohol.
Mar 17, 2014 | Brother DCP 165C Compact Color Inkjet...
Error code 50
Error Code E50. This printer error code flashes when the fuser unit of your Brother multifunction printer gets damaged. When this happens, it is a signal that you must replace your printer's fuser unit
Mar 15, 2011 | Brother Multi-Function Center MFC-240C...
What is error 50 on the precor efx546
Precor uses the same error codes for all of their units. Error code 50 is for excessive brake (eddy current magnet) current.
Mar 19, 2010 | Precor EFX 546i Elliptical Version 4
Lexmark X5150 All-in-One Error: 50
"When the printer fuser fails it prompts many HP laser printers to display an ERROR CODE 50 service code" same could be said about the lexmark fuser malfunction
replacining a fuser can be expensive might be better to get another printer unless you have a special bond like me i find it hard to just throw away things that have gone bad
Feb 01, 2010 | Lexmark X5150 All-In-One InkJet Printer
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Error message 50 and 30
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Apr 04, 2008 | Brother MFC-845CW multi-function...
Error 50
Do you have any more info? What happened before you got the error? Did the camera suffer an impact?
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot SD200 / IXUS 30 Digital Camera Logo
208 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
