Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Slow load speeds
All of a sudden my load speeads are very bad. They were very fast. My router is 8 years old. Do these things go bad after awhile/ ANy thoughts on why I am experiencing a sudden slow down? I also have a signal booster (lynksys).
Tony
  • Linksys Master
  • 6,487 Answers
Yes, when your router gets old it really get slow, you can try to load a updated firmware to this router and that should help for this concern, You can also contact Linksys tech support for further help this is the number 800-3267114.
Hope that helps........
Posted on Aug 23, 2008
Internet connot display web page all the time , and slow download speeds,modem adsl light coming on constantly.
Dealt with a lot of these. It is either :
1. Wrong password and ISP information - double check that everything your ISP has asked you to put in is correct
2. Bad phone connection - even if the ADSL light comes on (which means the router can see an ADSL connection from your phone provider) does not mean the line is clean. Pull out all the connections to your home phone, and just plug in the router to get it all up and running. Once happy reconnect one at a time all phones, digi boxes etc.
3. Adding to 2. - have you got a splitter? If so, change your splitter or reconnect, splitters can fail quite easily and get old fast - a bad splitter creates a lot of noise on the line, making the internet time out
It could be a router fault, they last about 4 years before they start doing silly things. But likely one of the above.
Try two sites once you are happy :
www.speedtest.net - to check your connection speed
www.pingtest.net - to check line quality
Dec 19, 2010 | Computers & Internet
I have Toshiba Satellite A100 running Windows XP and connecting via wireless to D-Link DIR-615 router. I can get a connection and access the internet but the pages take ages to load. I also have two...
You have a slow computer. To speed up page loading you might want to add an ad blocker to your browser to speed things up since the ads take up memory resources and slow down your computer.
Aug 23, 2017 | Computers & Internet
Incredibly slow wireless connection when DSL connection is fine.
anytime you transmit wireless and connect wireless you loose speed. a lot of routers have a buffer in them to regain the transmision speeds. the antennae needs to be at a 45 degree angle as well for best transmission and tight. there maybe static in the lines called ingress. a bad connector or a radio shack splitter will kill off hsi. make sure your splitter is over 1000 mhz. the 900mhz are garbage. your netgear may also be the problem, and may be subject to warranty replacement.. it is very common. i install netgear wireless daily and i have seen brand new out of the box fail. also like my wife, she forgets to remove the torrent files from the vuze downloader and ends up seeding 20 albums which slows us down bigtime.
Jan 18, 2010 | NetGear WGR614 Wireless Router
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
7 years old Dell loading slowly
Increase your RAM meory so it speeds up fast.
Also scan your computer with antivirus .
Jul 13, 2009 | Computers & Internet
Slow or no wireless speed, connection says excellent
Your router may be toast but here are a couple of things to try:
Please remember, I'm guessing here...
Before restoring to factory defaults, make sure you can get to the config pages using the rj45 (wired) ports. Do a speed test with a wired connection at http://www.speakeasy.net/speedtest/
1. try removing all security. No WEP or WPK. Also, use no mac address filtering. See if it speeds up. Go back to http://www.speakeasy.net/speedtest/ and try speed testing the wireless portion of your router..
2. If it has automatic channel selection, this may be acting up. So manually select channels. Then do speed tests at the web site (or any speed test web site of your chosing). You may find a screaming fast channel.
3. If this fails to help, use the reset to factory default button. Try setting up the router with NO security first and do speed tests. Use automatic channel selection first, do speed tests, and if all else fails, you can try manually selecting channels again. If the router works well, you might want to set up security again and retest.
4. If all this fails, buy yourself a new wireless 802.11N - (N1) router. They are screamin' fast and have better range.
Apr 07, 2009 | Linksys Wireless-G WRT54G Router
Motor is sluggish, Necchi Model#4795
Set machine to wind the bobbin to check for how fast the machine will run. I believe it will run fast or slow according to how hard you depress the foot control. If it runs fast and slow you have a problem in the machine. Most likely the machine, if turned by hand, is hard to turn and it needs to be professionally serviced. before it is ruined.
sewman7
Dec 29, 2008 | Sewing Machines
Will The LinkSys Router Model No: BEFSR41 Slow Down My New Laptop ?
Nope your computer is independent from the router and the only thing that will influence speed is how fast the router is in relation to your old one and your internet connection.
Jul 04, 2008 | Computers & Internet
Kenmore 80 series washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Fast Page Loads Slow Downloads
it really depends on how far you are from your Router. The farther you go, the weaker the signal gets resulting in slower speeds. Slower speeds will not affect web page load times (they are tiny parts of data) but will definately affect download speeds. You need to be as close to the router as possible or get perfect range. You can put the router at higher elevation in the room to get a better range to start with. Let me know if this works for you.
Dec 20, 2007 | ASUS WL-700gE Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
