JVC GR-DVM55U Error E06
Hey
I have about a 5 year old JVC Video Camera. I have a E06 Error Code coming up when I turn on the camera. The code says...remove and reattach battery/unit in safe guard mode. The battery seemed to be working fine before this error came up. Any suggestions?
  • rkjackson Aug 25, 2008
    Is my "E06" error code not related to the battery. Also, if it needs professional repair is a 5 year old JVC worth getting fixed? Any idea what it would cost for repair? I would have asked Coolguy but I couldn't figure out how to reply under the same problem.
  • 1,879 Answers
Click on the EXPERTS name to send a message direct
Posted on Aug 25, 2008
  • monk3ybidzness
    monk3ybidzness Aug 25, 2008
    and yeah - about the E06 Error Code - it's mechanical.
    honest suggestion - getting it repaired ain't worth it - get a new one
  • 6,487 Answers
Seems its the result of a tape jam. If you can remove the tape, you can reset the unit.Having it fix still worth and that shouldn't causde you that much...
Hope that helps.........
    Master:
  • 848 Answers
E06 error means electronic failure in the image pcb.......
Posted on Aug 23, 2008
  • gopinath pasupathy Aug 23, 2008
    you need to contact the service center to get this problem solved........
    Genius:
  • 3,422 Answers
HI,
"E06" it is the carriage mechanism that has failed. and will not carry the tape to the heads and thus is not passing the sensor that tells you if the tape is in position and then telling the unit as it should there is fault.
take it to the nearest dealer and get it fixed.
  • Priya darshan Aug 23, 2008
    There are no home remedies for this error.The only solution is to get it repaired.
  • Priya darshan Aug 25, 2008
    Please accept the solution no.4 as fixya.
Jvc gr-d350u. Constant E06 code with either battery or power adapter
if the screen keeps showing e06 device is in safeguard mode """"please remove or reattach the battery""""" If the error continues, please understand that it is a FAULTY BATTERY. This error is very common and results when the battery life has been changed or altered due to time elapsing. There is not a lot that can be done except to request a new battery. I performed more research on this and found that an equivilent may be purchased directly from jvc.com for a fraction of the costs then replacing the entire unit.
Jan 11, 2011 | JVC GR-D347U Camcorder
JVC GR-D32 model. Error Indicator notes E06 error. It states unit is in safeguard mode.I remove battery and reinstall as directed and does not fix problem.
Its gonna cost you more $ to fix it than it's worth it. Don't buy Mini DV anymore... save all your videos to your PC, and invest in a different media camera.
In other words... throw it away.
Aug 06, 2010 | JVC Video Cameras
JVC Camcorder Error code E 01
Your camera can not load mechanism completely(E01). Could have problem with mechanism or the mode motor itself fails. By the way, serial number is not necessary. Good Luck
Mar 20, 2010 | JVC Cybercam GR-DX95 Mini DV Digital...
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
Jvc camcorder
E01 means Mechanism has not fully loaded up to the stop position
E06 meansTape drive motor is not rotating or stalled.
Thses two faults indicate a tape jam. please remove the cassette and insert a new cassette.
Nov 02, 2008 | JVC GR-AXM17U Camcorder
Jvc camcorder gr sxm37u
There will be a error code on the screen start from E01 to E06
Oct 16, 2008 | JVC COMPACT VHS-C CAMCORDER
JVC GR-DVM55U Reply
I strongly suggest you to buy a new one because the cost of repair will be equal to a cost of new one.If you want repair person just give me the zipcode and i'll give the contact details to you.
Aug 25, 2008 | Televison & Video
SAFEGUARD MODE ERROR CODE E06
Why not do what the manual says ? They're printed to assist you.
Jul 14, 2017 | JVC GR-D201U Mini DV Digital Camcorder
JVC GR D295U
note error codes displayed - if camera shuts off immediately ; if tape is inserted ? put camera to your ear and apply power : if more than one motor sounds ( or sounds ' jerky ' ) your tape may be damaged - no user serviceable options left ; if no tape is inserted ? check with stacy sample at jvc factory service in houston , texas - for possible warranty updates .
Sep 11, 2007 | JVC GR-D295U Mini DV Digital Camcorder
JVC GR-270U Blue screen with playback
a 1394 cable is specified for the GR - D - 270 but the GR - 270 U , not listed ( does your camera use VHS/c , or mini DV tape ? )
Aug 15, 2007 | JVC GR-AXM710 Camcorder
Televison & Video Logo
303 people viewed this question
Top Televison & Video Experts
