Question about Canon PowerShot SD200 / IXUS 30 Digital Camera
Error 30 I see the error 30 what should I do?
    Sergeant:
  • 255 Answers
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Posted on Aug 31, 2005
SOURCE:
How to fix err,30 on canon t3
Have a look here for error code 30
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/
Jun 20, 2014 | Canon EOS 1100D Rebel T3 Body Only Digital...
Error 30
This WEB site can help you with this error code.
http://fixingprinter.blogspot.com.au/2011/10/canon-printer-display-error-code.html
May 06, 2013 | Canon Pixma MG5220 InkJet Printer
Error code -SE-
Hi maaki41,
The error code SE stands for a keypad is held down for longer than 10 seconds. If you were not holding down a button then you have a defective key pad because of the sensor error. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 17, 2011 | Maytag Over-the-Range Microwave
Error 11
ERROR-11, 12, 17, 30 Dirty disc Clean disc.
ERROR-11, 12, 17, 30 Scratched disc Replace disc.
ERROR-10, 11, 12, 15, 17,
30, A0
Electrical or mechanical Turn the ignition ON and OFF, or switch
to a different source, then back to the CD
Feb 20, 2010 | Pioneer DEH-1800 CD Player
Error 12 and error 17 only for dvds
iiMesisage Cause Action
30, A0
i hope this answers and solves your problems.
Feb 19, 2010 | Pioneer AVIC-D1 Car Video Player
Error 12 and 15 what is that
30, A0
Feb 18, 2010 | Pioneer DEH-P2900MP CD Receiver...
Windows XP Error: category 102 event id 1003
look like a system crash.
try to go into save mode and do a scandisk
if not, remove any newly install hardware or software.
restart the laptop.
Nov 10, 2008 | Microsoft Windows XP Professional
PHASER 7700 ERROR 30
try this
The following functions will generate a Tech Rep Fault:
  • Error: 30: Belt Home Too long
  • Errors: 12, 13, 14, 15: ATC-YMCK Sensor Fail
  • Errors: 40, 44: Fuser Main/Sub Lamp Temp Too High
  • Enter Service Diagnostics
  • Highlight NVRAM Access and press OK
  • Highlight Clear Tech Rep Faults and press OK
  • Highlight the Tech Rep fault to be cleared and press OK
If you have had the error 3 consecutive times , you do need to send the snippet to the printer to clear the error. The instructions how to do it are in the download.
Other things. You may need to replace the accumulator belt.
You may have toner backed up in the waste auger, you can clean that out and replace the waste bottle.
Cause:
The plastic tab attached to the cleaning blade assembly was broken, this tab opens the cleaning blade waste assembly when the belt is lowered .
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. The waste toner from accumulator belt cleaner could not reach the waste bin and jammed the augur. This caused the grinding noise by stalling the accumulator belt motor. This causes an error 30 code to be displayed.
The belt cleaner does come as a separate part 016-1889-00 and is very easy to fit and much cheaper than a new belt assembly.
Error 30 is a Tech Rep fault. After three Error 30's, the NVRAM Clear Tech Rep Faults will need to be reset to be able clear the Error 30 message.
Mar 04, 2008 | Xerox Phaser 7700 Laser Printer
Canon PowerShot SD200 / IXUS 30 Digital Camera Logo
1,016 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
