Question about Dishwashers
Overfill protection float on Kenmore dishwasher
The manual said to tilt the overfill protection float by tilting it towards the back and letting it "snap" off. I did so, but now I can't get the float to snap back into whatever part it was snapped into. How do I get the float back in place. Right now it just slides up and down and will come out completely.
2 Suggested Answers
SOURCE: Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Posted on Mar 16, 2009
Dishlex Global 300 Dishwasher - ECO Light flashing - Manual indicates incorrect fill level - Manual suggests hold ECO button for 10 Seconds. No success. Have tried pressing and holding buttons - no...
eco light sometimes indicates that water has got into the bottom panel of the machine. A float switch is underneath to protect the machine ( and your kitchen floor from being flooded. ( Either from overfilling or a leak) If you tilt the machine backwards see if any water runs out. If the machine restarts , then you will have sourced the problem. Should the flashing start again later, you may have a water leak underneath. Also check the lower door gasket to make sure its clean. If the gasket is dirty, sometimes water builds up behind the gasket and drips over the front of the tub into the bottom panel underneath causing this symptom. When cleaning the gasket, be very carefull!! The edges of the door at the bottom are razor sharp..
Jul 26, 2011 | Dishwashers
I have a ASKO D3111/8 dishwasher that will not stop pumping unless i turn it off at the power?
Hi alan gorman1,
I believe the Float Switch has been activated, do the following:
- Tilt the dishwasher back 35 Degrees.
- Keep it there until water stops running out the side (If any)
- Then tilt the dishwasher forward 35 Degrees
This should empty water trapped in the lower part of the Dishwasher, and deactivate the float switch.
Kind Regards
Jedemeyer1
* Hope this solution helped you, if it did, please rate it.
Jun 10, 2011 | Dishwashers
I've got a Smeg DI612CA9 D/wahser. When I turn it on it pumps down as normal but won't stop pumpimg down even when the door is opened. If I leave it for +hrs it will allow me to start a wash cycle, but...
Hello Myles,
Your description suggests water has leaked (and is probably still leaking) into the bottom of the dishwasher under the wash compartment and is tripping the anti-flood protection system. The pump continuing to run even with the door open would confirms that the anti-floop protection has been activated, although the problem could be a fault with the float-switch for this safety feature.
I suspect you have a leak. When you leave the washer for a few hours a certain amount of this water will evaporate. This allows the float to fall deactivating the float-switch so you can start a wash cycle. However, as soon as you start a cycle, more water leaks into the bottom of the washer and the anti-flood protection system trips again.
You really need to have a look under the wash compartment and check for the presence of water there before you do anything else. If there is water in the bottom, pull the washer out and tilt it backwards about 10-15 degrees to allow any water to run out. You should then be able to use the washer again, but if there is a leak, the problem will return fairly quickly, so this really needs to be investigated fully.
If you pull the washer out to remove any water in the base, I'd suggest putting some old towels behind the washer before tilting it, to absorb any water that runs out. I also suggest getting someone to help you tilt the washer as they are heavy and the bottom can slide out when you tilt it.
You should also switch off the dishwasher and the power supply and close the water check valve ot disconnect the water supply hose before attempting this
Hope this helps.
Regards,
BElectric
Mar 22, 2011 | Dishwashers
The Pots Pans button flashes and won't let me change it
Go to your circuit breaker panel and turn off the circuit that feeds you dishwasher. Leave it off for three minutes. This will reset the program and should solve your problem.
Apr 04, 2009 | Kenmore 15634 Built-in Dishwasher
Leaking?
I had this problem, our kenmore dw would leak maybe 1 out of 5 runs. found that the overfill float was so full of crud and calcium that it was weighing it down, and alowing too much water in - thus leaking out the top of the shaft of the float.
You must unlatch the float below the dw, very difficult, try a mirror, you also must remove the micro switch attached to the bottom of the float first. This fixed the problem!
Jan 18, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Nov 11, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Dishlex DX300
Hi Chris,
the problem is caused by water build up at the bottom of the machine due to dust/dirt. Take the machine out, disconnect from the power supply and empty of dishes. The floor will get wet, so you might want to place a large towel under the machine. Now tilt the machine at least 45 degrees towards the back. Watch where the water drips out and tilt further towards that corner. It's best to let the tilted machine rest on a table or bench so you don't have to hold it continuously. Wait about 15min, clean your filters and switch it back on! Worked a treat on mine!
Best of Luck
May 03, 2008 | Dishwashers
BEKO D3422FW Dishwaser stays on the pump out cycle.
I can confirm Solution #2.
This usually happens whe you have a blockage in the waste pipe. For some reason, once you've cleared the blockage, the dishwasher doesn't detect that water has now passed through the system, even if you send through more water via filling the base (I did this about 4 times totalling 24litres of water and it still didn't reset).
Tilt the dishwasher back (I only had to tilt it about 30 degrees), this resets whatever switch it is that turns the pump off and allows it to fill with water.
Oct 23, 2007 | Beko 24 in. D3421F Free-standing...
Leak
first get a level and make sure the unit is tilting back ever so slightly. Also make sure no solids are under the float switch and screens in the unit. It could be overfilling.
Nov 25, 2006 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwashers Logo
589 people viewed this question
Top Dishwashers Experts
