Question about Olympus Camedia E-20N Digital Camera
WCON When I use the WCON-08B with the onboard flash I get a dark semi circle at the bottom of my
    Master:
  • 852 Answers
The built-in flash cannot be used with the WCON-08B. The WCON-08B blocks the path of light from the built-in flash. An external flash should be used, for example, the FL-40 sits much higher, therefore the path of light is not blocked by the extension lens.
Posted on Aug 31, 2005
I used the collimation eyepiece to collimate my telescope.But I dont know if it's properly aligned. The knobs on the bottom of the tube are turned fully clockwise, and the black dot in the eyepiece is...
Before you do anything else, take the scope outside on a good night, find a semi- bright star (Polaris will do). Let the scope cool down! (about 45 minutes) use your highest power eyepiece and put the star in focus.
Now take the star out of focus (inner focus or outer focus) you should see a dark circle in the center with symmetrical rings around it (airy rings). If the dark circle is in the center and the airy rings are symmetrical, your telescope is collimated
Check both inner and outer focus, they should be close to the same. If not you should re-collimate.
Best done with fainter stars but for now stick to the brighter ones.
Because I own 3 scopes, I use a Hotech laser collimator. its quick and easy. Worth it if you travel with your scopes to dark sites
A good guide on how to collimate
http://www.skyandtelescope.com/howto/diy/3306876.html
Oct 16, 2010 | Celestron NexStar 130SLT (31145) (306 x...
I can see a semi circle on my screen
If you see a white outline of a semi circle it is a pressure mark caused by something pressing down on that part of the screen. Nothing can be done except to replace the LCD if it bothers you. Good Luck!
May 30, 2010 | Dell Inspiron Mini 10 Notebook
Dark semi circle shadow and pics too bright
Are you using a lens hood? Is your ISO set too high?
Apr 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
Samsung SP42W4HPX, black semi circle bottom of screen & 3D effect
sir/mam the problem of your t.v is weak picture tube,i have encountered for that kind of problem already.
Jul 31, 2009 | Televison & Video
Lcd covered in water,semi circles at bottom of screen
could be pressure damage from objects at it, hard to say, usually the glass would have spider cracks around each presure spots, but LCD is soft so the pressure damage explains what happened.
If the spots are near the bottom the liquid may have crept upward from the edge , try a hair dryer on a spot and see if it changes indicating liquid is still in there.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 22, 2009 | Televison & Video
Different symbols flashing and bleeping
Check ther coolant level, if this is ok, its possible the sensor on the coolant resevoir faulty. the other warning light sounds like the brake pad warning light. is the warning yellow?
Feb 17, 2009 | 1999 Audi A6
Accessories lenses
Olympus offers the following add-on lens accessory options: MCON-35 Macro Extension Lens (equivalent to 1/4 life size, subject size that will fill the frame is approximately 1.4" x 1.9" f2.4 Tele/f2.0 Wide, 72mm filter size) minimum focusing distance - 4.75 inches. WCON-08B Wide Extension Lens (equivalent to 28mm f2.0 in 35mm photography, 105mm filter size) minimum focusing distance - 3.6 inches TCON-14B 1.45X Tele Extension Lens (equivalent to 200mm f2.4 in 35mm photography, 86mm filter size-tentative) minimum focusing distance -1 ft. TCON-300S Tele Extension Lens (equivalent to 420mm f2.8 in 35mm photography, 49mm filter size) minimum focusing distance - minimum focusing distance - 3.9 ft.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Macro mode
The lens shade is blocking light from the built-in flash, remove the lens shade.
Olympus Camedia E-20N Digital Camera Logo
63 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
