Question about Canon PowerShot SD200 / IXUS 30 Digital Camera
Error 18 I see an "E18" error code what does it mean?
    Sergeant:
  • 255 Answers
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Posted on Aug 31, 2005
What does 0406 error code on BEKO washing machine mean
Hi, Beko error code format is usually preceded by an E and goes from 1 to 18 or 19. E.g.: E1, E2...E18. Please post a picture of the error code display and your model number and one of the readers may be able to help you.
Oct 09, 2018 | Beko Washing Machines
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
What does E18 mean on the screen of my camera?
E18 is a lens error. You might try this repair technique:
Canon E18 Error
Jun 04, 2015 | Canon PowerShot A20 Digital Camera
What does the error code "E18" mean on the powershot S1 IS camera
Hi!
The e18 error is very common on Canon cameras, it means lens error. There is actually a dedicated site for this issue. Here's a link for you:
http://www.e18error.com/
Please let me know if it helped.
Regards,
Bogdan
Aug 26, 2011 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot A510 error code E18. What does it mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The problem usually happens because dirt or sand get into the lens mechanism. If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
Jul 11, 2011 | Canon Cameras
Fault code e18
Camera lens must have taken an impact, Because that error code means zoom lens error Have to unjam lens. Has to be done by a repair shop/person. A lot of labor to take apart, TC
Aug 31, 2009 | Canon PowerShot A70 Digital Camera
E18 error code keeps showing up. The camera won't shut off.
check out the below link to know what ur error means and how to fix it
thank you have a nice day
May 11, 2009 | Cameras
E18 Error message on my Cannon PowerShot A410
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 14, 2009 | Canon PowerShot A410 Digital Camera
Canon e18 error
error code e18 means that the focus motor gears a jammed, dirt or grain of sand in them. you can try to fix it by gently banging the camera on somthing soft, their are also instructions on web on how to disasemble and fix this fault. BUT unless you have some skills, the right tools and conditions i would not attempt it. leave it to the experts. their are several flat cables, without actually seeing I cant tell you
Aug 30, 2007 | Canon PowerShot A85 Digital Camera
Canon PowerShot SD200 / IXUS 30 Digital Camera Logo
79 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
