Troubleshooting NEC CD-530
Hi cmv9... I don't understand your comment "... it does not seem to have come through." I have a single disc CD player from NEC. The model number is CD-530. Ten seconds or so after I power on an "E" shows in the display window. I can load a CD but it does not play. It does not even spin. I know this because I have taken off the cover and seen the lack of movement. Can you help?
Thanks.
John
SOURCE: Nad C542 Troubleshooting
This is an issue that has plagued the 541I and 542 models - some units worked fine and some units had similar issues as the ones you mentioned. It was suppsoedly fixed beginning with Serial Number G56C54224800 but I know someone who has a later serial number and had the same issue. It could be the laser or the transport or both. Simply put NAD has a quality control issue. There products still produce great sound but the great sound at a reasonable price is seemingly coming at great cost - the lack of consistent quality.
Posted on Nov 18, 2007
SOURCE: The DVD player does not recognize disks that it used to play before.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
Hope this helps.
-Ed
Posted on Jan 16, 2008
SOURCE: Not Recognising a CD
I got a second hand 541 a few weeks ago. After many hours of listening pleasure an no problems at all, the machine stopped spinning CD's, both copied ones and original ones.
The sollution for my problem was simple after some figuring out.
Open the CD tray.
Power off the unit with the tray open.
Open it up.
In the CD frame in the back there are 2 srews that hold the CD engine unit in place. I untidied these screws just a little bit.
I also untidied the screws that hold the cd clamp cover on the top a little.
After this it loads all my CD's fine again.
Posted on Feb 28, 2008
petraman7
  • 1175 Answers
SOURCE: 3 yr Old CD Player not recognizing discs
Laser might not be faulty but just a dirty lens/ rail assembly.
If thou darest open the thing, clean the lens ( GENTLY) with a swab of glass lens cleaner. Clean the chrome runners for the optics assby with a swab lcaed with WD40 or silicone.
Posted on Jun 26, 2008
CMV9
  • 594 Answers
SOURCE: Good afternoon. I
i need the model number off your system. or you can go to www.nec.com
it will take you to the global site and you choose your country and support and downloads....
please do not for get to rate and comment about your experience today.
Posted on Aug 23, 2008
How do I delete a playlist from windows media player
Hi ginger w
DELETING PLAYLIST FROM WINDOWS MEDIA PLAYER
You don't say which version of Windows Media Player you have or which Windows Operating System you are using.
However, generally, to delete a playlist:
Single left click to highlight the playlist to be deleted > single right click on highlighted playlist > single left click on 'Delete' > Are you sure? (single left click to select either Delete from library only or Delete from library and computer) > single left click OK.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
Oct 02, 2011 | Microsoft Windows Media Player
How do I delete a playlist from windows mefdia player
Hi ginger w
DELETINGPLAYLIST FROM WINDOWS MEDIA PLAYER
I hope this helps.
Hi i have a Farenheit tid-530 and when i play the cd on the dvd player it randomly turns off and switches to the fm radio is there any solution or is there a problems with the wires?
When mine did this i bought a cleaning disc and it stopped this. Untill a few months later. Just use it once a month or so and it shouldnt happen anymore.
Jul 10, 2011 | Farenheit TID-530 Car DVD Player
My Verbatim DVD +R DL disc burned on my NEC 2510A DVD-RW will not play in a desktop DVD player but will play the computer it was burned on. The computer is running Windows 7.
It;s possible that you may have left the disc open or re-writable. Check this first.
The settings will be located in the software you used to burn the disc. Easiest would be to start a new burn session and read the available settings throughout the window prompts. It may also be located in advanced settings, if you don't find it this way.
Jun 14, 2011 | NEC ND-2510A DVD±RW Dual Layer Burner
How to fix the ERR1 in Toyota Yaris CD Player
Error #1 means unreadable disc.
This condition appears a few reasons:
- Burned disc. These players don't always like burned CD's. Try burning your discs slower (like 8x instead of 40x, yes this makes a difference) or using higher quality CD-R's. Made in Japan discs are the best (Taiyo Yuden). Yes this also makes a difference.
- Dirty or scratched disc.
- Dirty Laser. I've had really good luck with those CD cleaners. It is a CD with some small brushes on the bottom. Worth a shot.
- Deck is plain junk.
Additionally, in this lnk could find other details about fix-error-1-cd-player.html
Hope this helps (remember to rate this answer ans send us your comments).
May 25, 2011 | Car Audio & Video
Drawer opens when the player is switched on
hello marc you have a dirty laser,blocked sensor or even a misaligned condition try this clean the lens put a disc and turn it off with the tray inside wait about a minute and turn it on saludos
Jan 11, 2009 | NAD C521 CD Player
Troubleshooting an NEC compact disc player problem
im sorry but it does not seem to have come through.
Aug 23, 2008 | Audio Players & Recorders
Stanton C304 Single Top... Problem
i had the same problem on the c303. ended up sending it to FL for fixing. when i got it back it worked fine for a few days then other issues such as not reading disc. unfortunately i could only recommend another manufacturer since this one seems unreliable.
Aug 22, 2008 | Stanton C304 Single Top Loading CD Player...
128 people viewed this question
 Grubhead
Grubhead
