Question about Olympus Camedia E-20N Digital Camera
TCON When I use my TCON 14B or TCON-300, my image appears in a small circle with black
    Master:
  • 852 Answers
The focal length set on the camera is wrong. If you are using the TCON series extension lenses the focal length needs to be set at full telephoto, 36mm.
Posted on Aug 31, 2005
Sharp LL-151MU - Image turned black and white and flickers with a checkerboard like grain to the image. Any one know what area of the circuit board this may be?
It could be connections to the panel via the flat cables or the LVDS cable that goes from the main to the Tcon, or it could be a bad Tcon
Oct 29, 2017 | Sharp Televison & Video
I have a Vizio E701i-A3 Edge lit LED TV. I looks like an 8 inch strip of the LED edge lights along the bottom are not working. Do I need to replace the light or the T-con?
Tcon is the board that sets the tone for the whole image. If you have a small section that appears to have no backlight then the tcon is not your likely point of failure.
Sep 06, 2016 | Vizio Televison & Video
Black circle and vertical lines in 42LG5000 LCD TV
What board did you change?...the Tcon?
Mar 04, 2018 | Televison & Video
I've cleaned the glass and still have a black line on the image
Scan a document in 300 dpi in full width. Check where the line appears in the image. For example if the black line appears at vertical position say 1900, then it means the dirt is at 1900/300 i.e., 6.3 inches from left. Clean the area thoroughly. Check if any pin had created a scratch in the glass. At different contrast levels, if the line appears different, it is definitely unclean glass. On the contrary, if the line appears constant at various levels of contrast, then it is possible that scan module is faulty.
S. Mohan, India
Aug 04, 2011 | Canon DR 2080C Path-Through Scanner
Red/orange color
If your set is led or lcd your Tcon board is getting to the end of its life, its the lowest cost board in a TV
Dec 01, 2017 | JVC LT-32P679 32 in. LCD TV
Water in LCD display
Once you get a dead pixel (black dots), there is no way to repair that part of the screen
Sep 20, 2009 | Computers & Internet
Blue circles on images forehead, cheeks and chin.
Try cleaning the contacts on the connectors going into and out of the Tcon board, if that doesn't fix it replace the board, here is the manual if that helps.
Samsung HL S4266W Owner Instructions Manual
Jan 06, 2018 | Televison & Video
Hi can this OLYMPUS TCON-14B TELE EXTENSION LENS fit my olympus e410 can you let me no thanks
no it will not.. it is designed as an attached to a fixed lens for some point and shoot cameras
Sep 07, 2008 | Olympus Cameras
Accessories lenses
Olympus offers the following add-on lens accessory options: MCON-35 Macro Extension Lens (equivalent to 1/4 life size, subject size that will fill the frame is approximately 1.4" x 1.9" f2.4 Tele/f2.0 Wide, 72mm filter size) minimum focusing distance - 4.75 inches. WCON-08B Wide Extension Lens (equivalent to 28mm f2.0 in 35mm photography, 105mm filter size) minimum focusing distance - 3.6 inches TCON-14B 1.45X Tele Extension Lens (equivalent to 200mm f2.4 in 35mm photography, 86mm filter size-tentative) minimum focusing distance -1 ft. TCON-300S Tele Extension Lens (equivalent to 420mm f2.8 in 35mm photography, 49mm filter size) minimum focusing distance - minimum focusing distance - 3.9 ft.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Olympus Camedia E-20N Digital Camera Logo
101 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
