Question about Toshiba PDR-M700 Digital Camera
1GB SD memory card problem
I have put a 1GB SD memory card in my camera and get "this card cannot be used" message. However, the card is fine. Any advice?
  • Anonymous Nov 18, 2008
    can a 1gb sd memory card be formated to use in this camera
  • Anonymous Dec 13, 2008
    I have the same problem with a card that I bought on vacation. I know that the card is fine because I use it in other applications. HELP !!!
  • 10,594 Answers
Your camera is an old model and can't handle big memory card. Use only 128 or 256MB card in this model.
Posted on Aug 23, 2008
I cannot format the memory card using my Canon Powershot SX110 IS Digital Camera. The option is greyed out in the menu and an error message saying that the card is locked is on the screen. THE CARD IS NOT...
You don't give any details about the card that is not working in your camera. I suspect it is not an SD card but an SDHC (high capacity) card. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If this is the case, try a card of 1GB or less. This will hold plenty of pictures, 60 times as many as the 16MB card. If you really need more space then just carry a spare 1GB card and swap when you fill the first one.
Jan 04, 2011 | Canon PowerShot SX110 IS Digital Camera
How big a memory card can you put in a DMC-FZ20 camera? I just got an 8 GB card and get "Memory Card Error" all the time.The old 256 MB card works fine.
An 8GB card is not SD, but SDHC (High Capacity). SDHC cards fit the same slot as SD cards, but they are slightly different and many cameras do not work with them.
I have a DMC-FZ20 myself, and use a 1GB card. That is really plenty of space. If you want more (going on holiday?) then just carry a couple of spares. The manual doesn't mention memory cards larger than 1GB. Probably there weren't any when it was written.
Dec 05, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
Why can't you use 8GB memory card in Z710
I have a kodak z710 camera with a 2 gig card in it. I was wanting to get a 4 gig sdhc and i wasn't sure if the HC would work with this camera. HC stands for high capacity which means it allows the camera to load files on to the card faster. this may be the problem the kodak may not be HC compatable. but as i have said i have a 2 gig and it works fine with that. and i have a friend that has a 4 gig in thiers but once again i don't think it is HC so i would exchange the card if you can for just a regular SD/MMC card or SD card
Jan 20, 2010 | Cameras
Trying to install memory card did format and
Although you haven't stated the make, model and capacity of your memory card the information in your question suggests that you have used the wrong memory card.
The CD33 is compatible with SD memory cards but not with the later SDHC models (the HC means High Capacity). They'll fit into the camera just fine as they have the same shape as an SD card, but the CD33 chipset is incompatible at the basic hardware level and cannot format SDHC cards.
To complicate matters further, the original SD specification allowed up to a maximum 2GB, and this was later extended to 4GB but hardly any SD devices can use the 4GB cards without a firmware update. No firmware update was ever released to allow your camera to use 4GB SD cards. Your camera was also designed before 2GB SD cards were available so whilst it may be compatible in theory it was never tested with them.
I'd recommend that you stick to 1GB maximum SD cards unless you use a Kodak branded 2GB version: Kodak's website claims that your camera should work with their own brand card of that capacity, so if it doesn't you can claim on their warranty for a refund or maybe an exchange for two 1GB cards.
If all this is incorrect and you're using a regular SD card of no larger than 1GB then you either have a faulty card or a faulty camera. The only way to find out will be to try a new 1GB SD card from a major brand name. If the camera proves to be faulty then it's beyond economic repair as labour costs for diagnosing the fault alone will exceed the camera value.
I hope this reply has been of assistance and ask in return only that you rate my answer.
Nov 10, 2009 | Kodak EASYSHARE CD33 & Printer Dock Series...
My camera memory is full and does not recognize my SD card
Are you using 2GB sd card or more? If yes Please used only atleast 2GB or 1GB SD card. if your using more than 2GB is not compatible on your camera., Gudluck!
By d way if you using the recommended memory card and still you have that message call precision camera and binocular repair to set the camera for repair 1 800 665 6515
Oct 30, 2009 | Kodak EasyShare Z740 Digital Camera
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Card Error Message
the error message is because the 2gb sd card is not supported (is too big for the camera)
try 1gb sd card and it should be fine
Jul 17, 2008 | Samsung Digimax 4010 Digital Camera
Samsung nv3 sd 'card error ! ' message
my camera say card error, can u help?
Apr 04, 2008 | Samsung NV3 Digital Camera
Toshiba PDR-M700 Digital Camera Logo
169 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
