Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
There is an energy save setting on your controls. Turn that off if you don't want tv to keep turning off while you are changing inputs. Hope this helps.
Never owned the this TV, but from what I can tell the outside edges on either side should have a series of screw holes. Even if you can't see the actual screws, there are philips head and there are in the bottom of those 4 or 6 holes. Take those out to get the TV off the stand.
Those may also be covers for a less complex connect to the spot where the additional speakers normal mount. Either way, remove still starts there.
