Question about Motorola Mobility RAZR V3
Water in my phone it switches off when I try to use it
My phone got soaked and switches on but goes back off if i use it
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Remove the battery is what you would normally do and then place it in the sun light to dry. Have you done this already?
    Worldvet
    Brigadier General:
  • 7,752 Answers
ANNJ - you should take the phone to a mobile service center and ahve them service the phone first.
WORLDVET - if you are a tech would would you advice them to do that instead of having the phone professionally service knowing that if you do that by allowing it to just sundry that does not do anything to the parts that are still covered by the housing...that is not a GOOD SOLUTION FROM YOU
Posted on Aug 25, 2008
Cricket phone screen goes white
You could try and have it repaired but most likely the damage has already been done to the phone so no guarantee it's even fixable. I'd get a new phone maybe one of the water proof one's :)
Sep 10, 2013 | Cricket Wireless Cell Phones
Tip
Dropped the cell phone or mobile in water
Dropped the cell phone in water
If you would have accidently dropped your cell phone in water or it fell in water you can try fixing it be these below tips
1. Remove the battery of the mobile and try drying it with a hair dryer
2. Put the cell phone in a raw rice container for a day, the rice will soak the moisture and the mobile will become dry from inside
3. After that put the battery back on and try switching, there are more chances now that it will work
4. Never try to instantly switch on the cell phone after taking it out from water you should follow the above steps, switching it on instantly can lead to short circuit in mobile and the cell software can get damaged
5. You can also put the phone in light sunlight (not in very hot direct sunlight) after removing the battery do not put the battery in sunlight though
6. Also make sure you keep the SIM card out of the mobile
By taking these steps you can make a fair attempt to save your mobile from dying.
Regards
Vikram
on Dec 02, 2009 | Cell Phones
Which part in a cellphone is affect dat makes de phone not to switch on if there is water damage
Yo! its the board if the phone that is soaked. you should try to sun-dry the phone so the water goes off. after, try to switch it on again.
Jul 24, 2011 | Nokia Cell Phones
I droped my blackberry in the bath its switching on then cutting out the battery seems to be ok can you advise
What i've always done with a waterlogged cellphone is place it in a bowl of rice with a lid on it. Make sure that the rice is covering the phone (also make sure that the phone is turned OFF.) let it sit submerged in rice for a week, pull it out and try it. Should be fine.
Mar 29, 2011 | Cell Phones
I dropped my phone and it could not on now
Due to hazard some phones are not working. If you dropped in water try with this steps.
  • Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately.
  • If the phone will turn on, you can try to make a call to be sure it is working properly. If you put your water damaged cell phone back together and it won't turn on, it is likely that some water has gotten down inside the phone.
If dropped in floor, please bring it to service center for repair.
Jan 04, 2011 | Cell Phones
I mistakenly dropped my Nokia 1202-2 handset in water. Since then the screen shows a white display, and not the normal display. What do I have to do to get it back in shape.
Try to get it dry keep it in hot place after removing the battery leave it for 2 days and then try to charge the phone, check when you switch on the charger any sound comens of starting the chargeing process, if possible try the phone with some other battery, as the service center is saying it cannot be repaird may be the interner circuits may have fgot damaged
You can also use a hair dryer after opening the cell phone.
Do not put the battery on or switch on the cell till the time you are not sure its dry completely.
You can also try this leave the phone in a bag of raw rice for a night it will become dry as the rice will soak the water
Check if this helps & let me know
Dec 01, 2009 | Cell Phones
Wet Phone with Download screen
it may sound funny but put the phone, battery and nething else that got in a bag of dry rice. it will soak up any water left in the phone. that may fix your problem.
Sep 13, 2009 | Samsung Propel A767 Cell Phone
My samsung SGHJ700 fell in water.iwhat should i do?
The following method can be tried when everything else failed and the phone went through the washing machine, fell in salt water or was in dirty water for a long time etc.
Remove as many parts as possible (Sim card, covers, battery)
1. Soak the phone as soon as possible in distilled water to dissolve any dirt, salt, soap etc ( an ultasonic cleaner will be helpful )
2. Repeat step 1 if necessary ( depends how dirty the water was )
3. Soak the phone in Iso Propyl Alcohol ( a very short time in an ultasonic cleaner will be helpful to dissolve the distilled water in the alcohol )
4. Let the phone dry thoroughly,
5. Cross your fingers and switch it on.
May 17, 2009 | Samsung J700 Cellular Phone
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. Catriver..post back
Apr 14, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Motorola Mobility RAZR V3 Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
