Question about Microsoft Office Outlook 2003 for PC
Received e-mail has stuck during download
Initially received 2 e-mails. 1st was received ok, second stuck after 298KB and froze. This repeats itself each time Outlook is used. I now have 7 e-mails waiting with some 13MB but cannot get past the first 298KB.
Help pse.
Rod
    Novelist:
  • 210 Answers
Quickest and best solution is to your your ISP's webmail to delete the email causing the problem. (or move it somewhere else so it won't be downloaded).
You haven't given any detail about who your provider is, so i'll just give you an example.
If you were an Optus cable internet customer in Australia, you could go to http://webmail.optusnet.com.au and log in there. You'll need to find your ISP's webmail URL on their website (or call them), then you can read and delete the email that's causing your hangups... the rest of them will come down after that.
Posted on Aug 23, 2008
How do I fix server error 8004849
This is from Microsoft:-
If you receive Server Error: 0x80048849 and/ or 0x80048820 in Windows Live Mail at home or while you're in your regular network, it may be due to the setting of the MTU (Maximum Transmission Unit) on the mail client.
If you get this synchronization error at a coffee shop, airport or a place from where you don't usually connect to the internet, we suggest synchronizing mail on your regular internet connection.
When the MTU setting on the mail client is larger than the MTU settings configured on network devices between your mail client and the mail client servers, some data packets may be lost, causing mail synchronization to fail.
Follow the steps given below to fix synchronization errors due to mismatched MTU settings:
Determine the MTU setting on your network device
Apply the MTU setting to your mail client
This is a trial and error process, and will be different for each user. You may have to repeat the procedure below a few times, before you can find out the MTU setting of your network device. Follow the steps below:
Open command prompt
Click Start ? Run ? Type cmd
In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1500
Notes:
The <Mail server address> is the IP address of the mail server that you are unable to synchronize with.
For Hotmail, 65.55.33.106 is the IP address for DeltaSync (mail.services.live.com).In this document we will be using this IP address as an example.
In the -l 1500, 1500 is the max MTU for Ethernet connections.
You may get an error like this (100% packet loss):
C:\Users\username>ping 65.55.33.106 -f -l 1500
Pinging 65.55.33.106 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 65.55.33.106:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
If you received the error above, subtract 28 from the 1500 bytes of data. In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1472
If you get a 0% Packet Loss with 1472, it means the MTU setting of your configured network is 1472
Note: If you continue to receive the error described in (b) above, repeat the above steps by subtracting 28 from 1472 bytes of data. Repeat these steps until you get a message for 0% packet loss. If you were able to communicate with the mail server at an MTU size of 1424, you will receive the following:
C:\Users\username>ping 65.55.33.106 -f -l 1424
Pinging 65.55.33.106 with 1424 bytes of data:
Reply from 65.55.33.106: bytes=1424 time=230ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=196ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=162ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=163ms TTL=241
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 230ms, Average = 187ms
Open command prompt as administrator (you must be an admin on the computer)
netsh int ip show int
You will receive a message similar to the following. Find the connection name that you use to connect to the internet and note the Idx value
C:\Users\Username>netsh int ip show int
Idx Met MTU State Name
1 50 1472 connected Loopback Pseudo-Interface 1
11 20 1472 connected Local Area Connection
To apply the correct MTU setting on your mail client, type the following in command prompt:
netsh int ip set interface <Idx value> mtu= <MTU setting of your router> store=persistent
Press Enter
For example, if the correct MTU setting was 1424 and Idx value of your connection was 11, you will type:
netsh int ip set interface 11 mtu=1424 store=persistent
If (c ) was successful, you will receive the confirmation message "Ok"
Exit command prompt
Restart your computer
Open WL Mail and see if the issue persists.
have Windows Vista Home Premium Recently unable to send or recieve Window...
Feb 12, 2015 | Toshiba Computers & Internet
How do I stop the red message light from blinking after I have received my messages
~*~*~ SOLVED SOLVED SOLVED! ~*~*~ After talking to both ATT and RCA with no success...I figured it out. ~*~*~ Plug your phone line into the "DATA PORT" on the back of the unit. Slide the "DATA PORT" switch to whichever line is showing it has a message. Press the corresponding Line# button on the front of the phone. (you should hear the dial tone) Dial your voice mail number. Let it answer, (enter your passcode if needed), then hang up! - That's it! example: MSG Waiting:L2 - I plugged the phone line into the Data Port and moved the data port switch to "2". I pressed LINE 2 on the front of the phone, dialed my voice mail number, it answered, I put in my passcode. (It said that I did not have any new voice mails), then hung up! That's it! Message Indicator light off!!! Repeat for each line that shows a (false) message waiting. ~~~Don't forget to move your phone line back into it's correct port on the back of your phone.~~~
Jul 06, 2012 | RCA 25414RE3 Corded Phone
Cant understand a voice mail left on yahoo IM. sound is low and indistingusable
Maybe the problem is with the voice mail sent itself. Maybe it was recorded in a very low quality that's why what you receive was low sound and indistinguishable. Compare it with your other received voice mail, if all is like that then maybe there is something wrong with your messenger voice mail setting. If not, then the problem is probably the voice mail sent itself.
Mar 01, 2011 | Yahoo Messenger
Aspire one email is recieving the same email repeatedly
I am assuming that this is a new problem and that your email worked properly before this.
If your email was not completely downloaded it will not be deleted from your isp's mail server so the next time you check mail everything will be downloaded again.
Try going to your isp's web mail access. It is usually found on your isp's website. Delete all the mail you have already received on your Aspire. That should lighten the load so when you check mail again with the Aspire it will all download and then be removed from the server.
If your email has never worked properly on this computer you probably need to configure the setting in your email program that says some thing like 'remove emails from server after downloading'. It is usually a check box.
Aug 23, 2009 | Acer Aspire 4315 Notebook
Unable to record or skip backr skip forward or skip back. I have tried the power switch bit several times.
In this type of situation the solution would be to complete what is called a Front Panel Reset, this can be completed by completely unpluggin the receivers power cord from the wall and leaving unplugged for 10 seconds and then plug back in- but do NOT power your receiver back on. The receiver will complete a reset process which may take up to 5 minutes, during this time the receiver will power back on by itself and go through the necessary screens, once the receiver finishes downloading the program guide you will be able to verify if the DVR issues are resolved. If this problem happens repeatedly or has already happened repeatedly, please contact me directly so I can assist you and we can rectify the DVR issue with another option. If the issue has not been resolved already or you are still experiencing please e-mail me at Kirstie.Filosa@Dishnetwork.com. I hope this helps you!
-Kirstie DISH Network
Aug 19, 2009 | DISH Network DVR-625 DTV Receiver /...
It hasn't received e-mails in 10 days!
Ensure your email box is not full. Also check you junk mail/filter settings.
Apr 17, 2009 | Computers & Internet
Mail not listed in order
Ok. Change the hierarchy to BY DATE, instead than BY NAME. (Just click on the DATE tab). The triangle pointing UP means NEWER FIRST, pointing DOWN means OLDER FIRST.
Mar 13, 2009 | Apple iMac G4 Desktop
E-mail received
Be notified that the date on your computer does not have anything to do with the date of the mails you received. The date are autoset from the server so they must be correct, maybe you are are checking a wrong mail or something like you are not taking proper note, you may still try and check ur computer's date and make sure it is correct
May 05, 2008 | Computers & Internet
Microsoft Office Outlook 2003 for PC Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
