Question about Goodmans W280NS Television
No picture I've just bought this goodmans tv (LCD) and its says no tv input. I have the aerial connected. Can you help?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Test with video or test the vga with your system if it fails ,just change your mainboard
Posted on Oct 11, 2008
I have an indoor digital aerial connected to a free view box but when I automatically tune the TV it comes up with no channels found check aerial connection
Possibly. Try rotating the antenna a little bit and retry tuning. Keep on doing this until you get your channels. If this doesn't work, raise the antenna as high as possible and try again.
Dec 20, 2014 | Goodmans GTVL19W17HDF 19 in. LCD TV
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
The picture doesn't hold. The picture shows just snow on the tv.
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Aug 25, 2014 | Televison & Video
I have a Goodmans 19"
Sep 12, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
I have just got a goodmans LD2271D HD ready digital lcd tv and for some reason it wont tune any help? i've been to the menu and selected auto tune and it still says no service.
This usually means poor signal , HAD THIS PROBLEM WITH MY MOTHER IN LAWS TV, Take tv to other aerial point in another room ( i brought mother in laws tv home to my aerial ) and do a retune,
This could sort things out.
Nov 09, 2010 | Goodmans 289NS 14" TV
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
Cannot find AV Channel on new Goodman LD2245WD to play playstatio
Check the the color system of the tv.if the tv is auto no problem
video out from playstation to video input in tv.if this is made right with proper should funtion
Please Don't Forget To Rate "FIXYA" Me For The Help
Dec 21, 2008 | Televison & Video
"No Signal" but aerial working ok on other tv in house!
Your son more than likely changed the input source. You may be able to change it back by pressing the channel up/down button or you may have to enter the menu on the tv and change inputs that way. PS's will usually connect using a video input using a red/white/yellow cords. You may also want to ensure the connections are in their proper place as I do not know how savvy your son is at changing the setup over to play his PS. If you use a modulator to connect to the TV-either the PS or aerial- ensure that it is powered up also. I hope this has been of assistance to you and thanks for using Fix Ya. If I can be of further assistance let me know.
Oct 08, 2008 | Goodmans 289NS 14" TV
By an aerial do you mean a converter?
For the neew TV's you don't need one. Just plug it in using A/V cable (yellow is video, red and white are audio). Be sure you take note of which input you are plugging it into on the TV, and then use your TV's remote to change the video input (usually will be labeled video or TV/Video on the remote) to the one you plugged the PS2 into.
Jan 06, 2008 | Televison & Video
Televison & Video Logo
129 people viewed this question
Top Goodmans Televison & Video Experts
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
