Question about Philips PSS110/17 MP3 Player
My mp3sa110/02 firmware is not recodnised
When i try to get the firmware manager up it has an error message unable to open boot manager firware file what do i do .
  • Anonymous Aug 30, 2008
    i have uninstalled and reinstalled with disc , i can get all my music on flash but when i go to portable device and click on i get click here to add plugin for your device when i click a website cannot display comes up ,can you help me please
  • 8,596 Answers
Danny - make sure you only download the zip file from Philips website for your exact model # - the /02 at the end means it is not a United States model - go to Philips website and change your country first in order to gain access to the correct firmware file that you need
guest - the reason the page cannot be displayed is because the Musicmatch service that this player is tied to was cancelled in Oct. 2007
Posted on Mar 23, 2009
Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Mar 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Tip
Wii soft mod guide
Wii SoftMod Guide 3.1 - 4.1
Before we start into the process, you will need an SD card, at most 2gb capacity. This SD card will need to be formatted into FAT32 format.
Note: If you are on Wii System Firware 3.1, 3.3 or 3.4 You need to be connected to the Internet, unless you know the proper steps to upgrade using the Wii System WAD and Firware Updater 4.1 which I may include later.
First, download this file pack. Wii SoftMod 3.1 - 4.1 Pack
Download Readme file here. Wii SoftMod Readme
Step 1. Install The Homebrew Channel & BootMii
1. Put all the files from ‘Wii SoftMod 3.1 - 4.1.rar’ onto the root of the SD Card.
2. Insert the SD card into Wii.
3. Go to Wii Options, then go to Data Management > Channels > SD Card, then you will get a message saying "Load boot.elf?" , select 'Yes' and the Hackmii installer will run. (Goto the Channels first, then insert card or your console might freeze)
4. Install Bootmii as boot2 if you can, if not then install it as an IOS then go back and install the Homebrew Channel.
Step 2. Install Recommended CIOS
1. Go to Homebrew channel and run Trucha Bug Restorer, load IOS36, press 1, read the warnings then select 'downgrade IOS15', select to load IOS from SD card then let it do its job, keep an eye on what it is doing and make sure you select 'load from sd card' when it asks & don't get any errors.
2. Run Trucha Bug Restorer again, this time select to load IOS15 on first screen using dpad left/right, then select the IOS36 menu & install patched (select 'yes' on all 3 patches) IOS36 to slot 36, again using IOS from SD card.
3. Run Trucha Bug Restorer again, load IOS36 and this time select restore IOS15.
4. Run cIOS38 r14 installer, select IOS36 as the one it should use and then select wad install.
5. If your Homebrew Channel flips upside down then continue with the guide and when completed reinstall the homebrew channel.
Step 3. Update System Menu (Only for 3.1, 3.3 or 3.4 Firmware) Note: Internet Connection needed
1. Before you update to 4.1 make sure you have at least 250 blocks free or you will brick, install IOS60-patched first with Wad Manager using IOS249, then run Firmware Updater 4.1.
Step 4. The Final Step
1. Go to the Homebrew Channel and run Wad Manager 1.4 and load IOS249 (Default) and SD card.
2. Instal the following IOS.
* IOS38-64-v3610
* IOS50-64-v4889
* IOS53-64-v5149
* IOS55-64-v5149
* NeoGamma r8b17
Restart your console and your finished!
on Feb 18, 2010 | Video Game Consoles & Games
It will not turn on or charge
Hi, the Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
2. Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Hope it helps...
Have a nice day.
Feb 22, 2011 | Philips GOGEAR SA6045 MP3 Player
Go gear vibe has been frozen for about 25 min. wont shut off or anything
Hi, i stuck a pin in the reset hole, (to the right of the lock switch) and it shut it off, than all you have to do is turn it back on..
The Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
Memory Full
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
Hope it helped..
Have a nice day.
Feb 22, 2011 | Philips GoGear ViBE Digital Media Player
I closed a file after using it a few days ago. The next day I tried to reopen it and was faced with the message:"File already exists in memory." Since then I have been unable to open the file or...
reboot your computer and try again. This error simply means that that file is associated with a process and is active. identify the file name, and the press ctrl+alt+del. open the task manager and select the processes tab. somewhere in here there is a processes that is attached with that file. find it and 'end process tree' then try again If problem persists, try booting in safe mode by hitting F12 or F8 depending on your system at startup and select 'safe mode' if the file functions correctly then you may want to roll your system back to before you ran that file for the first time or if you are capable, you can track it down by identifying what processes are currently running and which ones appear after windows loads in regular boot mode. Then you can begin to isolate the process and possibly the problem.
(also, make sure that the file isnt in the startup folder)
GOOD LUCK AND PLS RATE THIS POST!!!!!
Nov 12, 2010 | Computers & Internet
When installing I receive an error message "Unable to open serial number file". After the install, if I try to open the application I receive the error "Unable to find serial number. Please make sure the...
To all that run into this problem like I have, here is the solution:
To install Suretrak 3.0 if you get “unable to find serial#” error:
  1. Temporarily Stop the Pervasive Sql Server Workgroup engine
  2. Install Suretrak
  3. After installation, copy wbtrcall.dll and wbtrv32.dll from the c:\pvsw\bin folder and paste to c:\windows\system and c:\windows\system32
Restart computer; all should be working now
Adrian (byrdadrian@yahoo.com)
Jul 24, 2009 | Primavera SureTrak Project Manager 3.0 for...
After firmware update control panel goes blank error light lit
can you tell me how you updated the firware and who did it???
you need a special service tool to update a canon copier,
sounds like it has failed and needs re doing,
usually only canon techs have access to the service tool you need and the Firmware.
May 31, 2009 | Canon Office Equipment & Supplies
My computer gives me an error message when i attach my MP3.
Go to Philips website
Get the updated Philips Device Manager for your model (rather than the one that came with the CD)
Once you have installed the updated Philips Device Manager, open it, and click on the Update button - it will update your player's firmware, which should resolve your issue.
If you are, instead, getting a message that says "File System Error" - return your mp3 player to the store or call Philips and see if you can get an in-warranty replacement.
-Tha Mp3 Doctor
Mar 06, 2009 | Philips SA3025/37 Flash MP3 Player
Boot error/won't save files
does the website have a firmware update avb for this memerex.com ect
Jan 27, 2008 | Memorex MMP8567 MP3 Player
Corrupt pictures
try to upload new firmware
http://gofurygo.blogspot.com/2006/11/archos-604-wifi-firware-updated.html
Dec 10, 2007 | Archos 604 WiFi Digital Media Player
Philips PSS110/17 MP3 Player Logo
94 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
