Question about Kenmore 96212 / 96214 / 96219 Electric Kitchen Range
Kenmore model# 790 94463700 serial# VF 735 37589
Oven/broiler won't work. flashes F90 ERR and unfortunately we don't have a manual for it because we got it as a floor model from Sears.
  • 15,935 Answers
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Started to bake an item, so I preheated the oven and started to cook item when all of a sudden an error code came up and stopped the oven from baking any longer. THE CODE( F95 ERR) came up and shut the...
unplug the range.
wait 1 minute.
wait 2 minutes.
Sep 23, 2010 | Kenmore 47153 Stainless Steel Dual Fuel...
My Kenmore Elite gas range is beeping and flashing F90, the door is locked. What can I do to clear this?
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^#$%
Aug 28, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Door lock indicator lit up but did not try to lock door. F90 err. After unplugging it for over 5 min and plugging it back in the door is still locked and will not unlock.
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jul 12, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
CODE F90
I have the same problem. my model number is Kenmore 970-556322. the whole stove is not working.
Oven door is not locked but got the message "door locked" on the control panel and won't allow reset via clear/off. and it shows F11 and F90 on the display, and the machine keep on beeping the whole day, tried to unplug and restart it next day, but didn't work.
Please help!
Jan 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
F90 Err on Kenmore Elite Gas Range 790.3670 How do I get rid of the error?
the F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board. It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Good Luck
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
What does the errror code F90 mean?
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore gas range trouble
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 20, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Oven door
dat, If your model starts with 790. there is a service flash regarding the hinges. Oven door not closing all the way. Affected model serial numbers VF-428xxxxx through VF-434xxxxx. There is a hinge kit for it, part number depends upon your full model number. You may want to call Sears and inquire about the service flash, you should be covered. Catriver..post back.
Mar 04, 2007 | Kenmore 96213 Electric Kitchen Range
Kenmore 96212 / 96214 / 96219 Electric Kitchen Range Logo
738 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
