Question about Zebra Eltron LP 2824 Thermal Printer
Zebra printer prints too short.
I calibrated the unit and the print outs are ideal. When i print a text label, the label prints short by .25 inches. to get the label out i have to press the feed button......
  • 32 Answers
If I remember correctly I corrected the same problem. What I did was opened printers and faxes and selected the printer. I then went into properties where you can select the size of label you are printing out. Once you do that the printer should align itself to the right size.
Posted on Aug 23, 2008
Prints label then prints a blank
This is always a calibration or label template size issue.
Feb 04, 2013 | Zebra Eltron LP 2824 Thermal Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
Printer only prints a small portion of the tag then stops
You may need to re-calibrate it. Fairly simple process, follow the instructions in the lcd menu. If that doesn't work check to make sure the label stopper is snugged up against the labels so there's no vibration or sliding of labels when printing, that will also throw off the calibration. Check the media sensors also to make sure they're free of dust.
Jun 10, 2010 | Zebra 105SL Thermal Label Printer
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
After calibration the first print is fine.. 2nd print to label seems to backup into the printer before the next print ..result in text missing info... workaround is ..I need to pull the label out a little...
Sounds like you are printing from Zebra Designer, if so all you need to do is click File/Printer settings/Advanced setup/tick the box marked "Top of Form Backup" OK, and then save your label file.
Nov 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
MY ZEBRA TLP 2824 PRINTS IN THE MIDDLE OF MY LABELS.
Don't shoot it, they're too hard to cook.
Make sure your program is set for the label size you're using. Also, there is a photo eye under the paper path that picks up the labels. It will, in time come out of adjustment. It can be cleaned with a swab and alcohol.
Sep 01, 2009 | Zebra TLP 2824 Printer
Zebra S4M label printer
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
Aug 13, 2009 | Zebra S4M Thermal Label Printer
Label not discharging far enough out of the print head
Hi
Can you tell what the printer is and what the material spec is?
Regards
Bob
Jan 11, 2009 | Zebra 110PAX4 Thermal Label Printer Print...
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Zebra Eltron LP 2824 Thermal Printer Logo
191 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
