Question about Amana Dishwashers
Amana Sofsound II Dishwasher, heated dry display light won't shut off
Push the button for a different option: it's like a radio button in Hypercard: one must be chosen, and choosing one will "unselect" the others.
Posted on Aug 14, 2009
Amana dishwasher not drying
get a new heating element
Mar 19, 2015 | Amana Dishwashers
MDB7130AWB thermal fuse
This might help. This is the thermal fuse you need if you need a replacement. Cost is somewhere around $25.00
Thermal Fuse
PartSelect Number PS342838
This part is used as a safety device to protect the dishwasher circuit from overload. If the temperature gets to high it will shut off the electrical current to the heating unit in the appliance.
This part works with the following brands: Whirlpool, Admiral, Estate, Inglis, Kenmore, KitchenAid, Roper, Maytag, Kenmore, Admiral, Crosley, Jenn-Air, Hardwick, Magic Chef, Amana, Caloric & Glenwood.
This part fixes the following symptoms:
  • Not drying dishes
  • Will not start
See part 26 in the diagram
Apr 08, 2013 | Maytag 24 in. MDB5600A Jetclean II...
My Amana sofsound dishwasher is not cleaning the dishes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 22, 2012 | Amana 24 in. ADB1500AWS Stainless Steel...
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Sandy grit left on dishes.
I was having a different issue with the same model but I think my issues solution might help yours. My dishwasher was not draining properly. It was the air gap that sits on top of the counter by the sink. It was clogged. We removed it and cleaned it out. Maybe if your air gap is slightly clogged as well it is not allowing the dirty water to flow out properly leaving you with gritty dishes. Hope this helps.
Jul 20, 2010 | Amana 24 in. ADB1200AW Built-In Dishwasher
Heating Element Won't Turn Off
Ok, this is a control fault that may be corrected by shutting the power off for 5 minutes. this will reset the chip set on the control board. plug the unit back into the socket after the 5 minute ait and check to see if the element is still on. If so, replace the control board.
May 29, 2009 | Amana ADW662EA Built-in Dishwasher
Won't start. Light on next to "heated dry" button & "#3" graphic
You have the lock activated. press and hold the HEATED DRY button for 3 seconds
May 01, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Jan 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag MDB6600AWW
Have you tried pushing heated wash, heated dry, heated wash then heated dry? Sometimes this will reset it.
Oct 27, 2007 | Maytag 24 in. MDB6600A Jetclean II...
Dishwashers Logo
810 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
