Question about Canon PowerShot SD110 / IXUS IIs Digital Camera
Error 50 I see an "E50" in the LCD display what is the problem?
    Sergeant:
  • 255 Answers
The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
Posted on Aug 31, 2005
3 Suggested Answers
Fishi
  • 255 Answers
SOURCE: Error 50
Posted on Aug 29, 2005
Fishi
  • 255 Answers
SOURCE: Error 50
The "E50" error code indicates formatting a storage card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another storage card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other storage card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the storage card for errors. Use ScanDisk to check the storage card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the storage card on the computer before you check the storage card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card. Follow ScanDisk's on-screen instructions to solve the problem.
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
SOURCE: E50 what does it mean, Hello & Welcome to FixYa E50 in your Electrolux is a motor error and is displayed due to a bad motor or a bad motor capacitor. Check if the motor brushes are ok
Hello Baldur Thor, thanks for your inquiry!
From what you have described your Electrolux air conditioner is displaying an "E50" error code. I do not show an "E50" has a valid error code. Could you please verify which appliance you are having issues with? Additionally, you could perform a reset on your air conditioner which is disconnecting the power from it for ten minutes. If you continue to have issues please reconnect. -Matt
Dec 21, 2014 | Electrolux Heating & Cooling
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
Screen is not displaying
I have the exact same problem;
Well I don't know exactly but I will OPEN my e50, check my battery...check everything and see what the problem is...I will write as soon as possible but I think that the problem is that it has been wet...Try drying it...
Jul 02, 2009 | Nokia E50
Error 50
Aug 31, 2005 | Canon PowerShot S20 Digital Camera
Error 50
The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot S1 IS Digital Camera
Error 50
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 50
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 50
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 50
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot SD110 / IXUS IIs Digital Camera Logo
124 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
