Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Coffee starts to brew and then stops
Hi, I have the same problem. It almost seems as if the electronics are screwed up and there should be a 'reset' button. But I couldn't find any reset. When I push the brew button, it runs for about half a minute and brews about 1/4 cup of coffee and then stops. In addition, the clock shows no hands unless I push on the button under the clock in which case it shows the actual time. In other words, it's not showing the amount of time it's breen brewing. That's why I think the electronics are screwed up and need to be reset. I used this coffeee pot about 10 times before that started happening.
  • 3 more comments
  • Gingerspice Aug 24, 2008
    Actually, I had already tried all that. In my latest attempt -- this morning -- I filled it up completely with water (the other times, when it stopped after 1/4 cup, I had only put in about 4-6 cups of water). When I filled it up to 12 cups, it worked fine. It ran all the way through. Go figure. Maybe it thinks because it's a 12-cup coffee maker, that's all it wants to be -- nothing less! In any case, I wouldn't buy that brand again.
  • vulcanopr Oct 18, 2008
    My coffee maker start brewing and I have to keep presing the brewing button evry minute until the entire pot is brew.
  • sandylink Oct 29, 2008
    I do have the same problem with the 12 cup Mr. Coffee maker, I just went out today and got another one but after reading that others are having the same problems don't know if I should use it. This is not a cheep coffee maker. I think that my husband is right just get a $30.00 coffee maker
  • fiddlindeano Nov 04, 2008
    My Mr Coffee pot does the same thing.
    Brews for about 3 minutes then shuts off. Then It will flicker on and off but never really finishes brewing the pot.
    Very frustrating !!!
  • JoanS633 Dec 30, 2008
    Same problem here -- it stops 2 or 3 times while brewing, 12 cup pot actually ends up as 10 cups (not sure where that water goes), takes about 40 min. for a 12 cup pot. I've had Mr. Coffee's for 45 yrs. but this one is a loser. Took it back. Considering Cuisinart.
I had the same problem and was reading about how the thermostat tells the coffee maker when to stop brewing. It sounds like everybody with this problem has the same coffee maker as I do.
Turn the dial for your "warmer plate" tempature down the whole way and then turn it up the whole way. I know this makes the coffee very hot but the cycle will brew until finished. It sounds like the thermostats are going bad. It is probably easier and cheaper just to buy a new coffee maker.
Posted on Dec 25, 2008
  • 876 Answers
You could turn it off, unplug it ( is it plugged into a GFI outlet?) empty it of water and clean every part that you can get off it thoroughly. then dry it carefully and then plugging it back in and just try running water through it with a filter in place. This is just a simple reset. (Even coffee pots are computerized now!)If this does not change anything,
I would clean this pot, put it back in the box and take it back to the store where I purchased it, along with the receipt or credit card receipt. I would not take "no" for an answer. You should not be having these problems after ten uses. Let me know how it works out.
Thank You Your rating is always appreciated.
Posted on Aug 24, 2008
Not working. Power on but shows a red flashing exclamation. Doesn't start making coffee.
Did you try to put grease on the brew unit to make it movement easy?
Feb 05, 2016 | Saeco Odea Go
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna - I turned on the coffee machine and instead of the usual whirling of the parts getting into place, it sounds like it is struggling to get into place. I looked inside and the bar is down where...
Hi Its hard to say with what you have said, but if the brew unit was cycling slowly, it may be the board. Close the door and make sure that everything is in but the brew unit. Turn the machine on and see if it cycles the gear in back to the starting point. It may take a few minutes to cycle if its the board. If it returns its the board. I have some boards.
Jun 13, 2011 | Saeco Vienna Espresso Machine
Coffee machine is displaying error message "BREWUNIT BLOCKED". Have tried opening up the machine to clean it out but nothing seems to be opening or closing properly!!
Remove the brew unit and clean the shower screen under the red o-ring, There is also a tube leading from the top of that o-ring to the discharge and is attached with 2 screws, remove screws slowly DO NOT LOOSE THE SPRING AND BALL that is under the fitting, clean out tube and the hole that leads to the screen, that should clear up the problem.
May 17, 2011 | Spidem Trevi Digital Plus Coffee Maker
My keurig machine starts to brew and then just suddenly stops. To reset I have to totally unplug the machine. Any ideas? I have cleaned the bottom needle and that is not the problem
Does it seem to be pumping air instead of drawing water from the tank? If so, you can put a thin layer of keg lube (got mine at Annapolis Home Brew dot com) on the silicone flange that is right under the water tank. You have to open the bottom of the machine and take out the two screws that hold the flange in place.
Apr 02, 2010 | Keurig B50 Coffee Maker
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
723 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Kelley Hopper
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
