Question about LG WM2042 Front Load Washer
Hot water not entering washer, not a hose or solenoid problem...
The hot water stopped entering the machine. After the obvious stuff checked out fine, we assumed a solenoid problem based on reading some of the problems others had and that we couldnt blow air through the valve when the solenoid was receiving juice. The cold side was working fine, so we ordered a new solenoid which sadly did not fix the problem.
Next, using a voltmeter, we then checked out the juice to the hot water valve and it was lacking (should have done this before ordering the new solenoid). Also we used the juice from the cold side to the hot valve and it works fine (also shoudl have done this before ordering new solenoid). We checked the connections and and the easy stuff with no luck. So we are thinking we have to order a whole new control panel. Question, is this a DIY project or are we out of our league?
  • youngbash200 Dec 16, 2008
    Noty wtaer not entering the washer machine.
  • 489 Answers
Before ordering a new control board, check the wiring harness to make sure there are no breaks in the wire from the water valve to the board.  If everything checks out, replace the board.  The board is not that hard to replace and all the wire connectors are not confusing.
Posted on Sep 29, 2008
My top load water dispenser stopped dispensing on the hot tub side, what do I do?
I'd follow the hot water supply hose to the back of the washer and and then - after unplugging it from the power - begin check to make sure hot water is available to the hose by disconnecting it and aiming it into the washer - and turning the water on. If it flows, check for debris clogging the strainer screen at the input to the washer. Then if ok - check the hot water valve solenoid with an ohmmeter. Compare it to the value of the cold water solenoid valve and if not within 10 - 15% - replace it. If you can check for 120 volts to the hot water solenoid SAFELY - do so - otherwise, stop and call a pro.
Dec 02, 2014 | Washing Machines
My Whirlpool Duet Washer #GHW900LW1 does not pull the hot water.
Sorry this answer is about 1 month late, but in case you're still having the issue, it is likely due to 1 of 2 possibilities (or combination of both).
Most likely, the small inlet screen, located on the back, (where the hot water hose enters the machine) is clogged. This is a common problem that restricts the flow of hot water into the machine.
To check or clean this, just unscrew the hot water hose where it enters the washer. It sits just inside that fitting.
The other possibility is a bad or clogged inlet valve. The inlet valve controls the flow of hot and cold water into the machine. It is opened and closed via an electric solenoid (part of the intake valve unit).
The inlet valve is the same unit that houses the screen I previously mentioned, and is just inside the back panel of the washer, where the two inlet hoses thread onto.
Oct 06, 2014 | Whirlpool duet Washing Machines
Model LAT8504AAE Hot water pressure has been reducing over time, little by little. It is now only cold water. All house supply line valves are open.
screen in hot water fill hose is probably stopped up.turn water off unscrew hose at both ends check for a screen,if not in hose check at water inlet on washer pop out screen clean under kitchen spayer and reinstall make sure you put hose washers back in the hose ends that should fix your problem!!!
Jun 12, 2011 | Maytag Washing Machines
Have a Roper RAS7133RQ3 top loading washer. Will not fill with water when turned on but will spin and drain when you take it through the cycles.
First, always check for the obvious causes, if you haven't already, we all tend to overlook these.
1. Are water valves open, and if so is there water.
2. Check hose filter screens for plugging, or hoses themselves,
After these possible causes have been ruled out, check machine's inlet for both hot and cold taps for blockage, other wise you most likely have a bad fill valve, which are fairly cheap and simple to replace. If you have hard water, this is your best bet. These valves have two solenoids, one each for hot and cold, one or the other will energize when the temperature selector switch is selected for hot wash or cold wash, if warm wash is selected both solenoids energize to allow both hot and cold water to enter the machine and mix to warm.
Hope this helps
kcomp1863
Jan 10, 2011 | Roper RAS8445KQ Top Load Washer
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Hot water will not enter machine. Screen filter is clean. Cold is OK.
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Feb 04, 2010 | GE WDSR2080D Top Load Washer
No hot/warm water coming into machine...checked all the obvious hot water heater etc. Somehow it not coming in from water hose/is there some sort of shut off valve on the washer....just getting cold water
There are 2 water solenoids on most washers. 1 for cold, 1 for hot. If the valve for the hot has a bad coil, or the wire connector has fallen off, it will prevent the hot water from flowing. If your live in area with very hard water, the valve may be closed shut from crud scale and such.
Nov 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Hot water doesn't work
Disconnect the hot water hose from the washer, put the hose over in the washer and run some water to make sure you don't have a plumbing problem. Look inside the valve where the water connects to the washer, there should be a screen that may need cleaning.
If everything looks and works good to this point then you will need a meter to see if power is getting to the water valve and to check the hot water solenoid on the water valve. No power to the water valve, then replace the water select switch. Bad solenoid, then replace the water valve.
Jan 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
Amana washer has no hot water - cold works fine
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Dec 04, 2007 | Amana ALW880WH Top Load Washer
LG WM2042 Front Load Washer Logo
94 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
