Question about Microsoft Xbox 360 Console
Power outage my power just went out and when i turned my 360 back on, i was disconnected from the internet and it didn't load the progress on live from the game before it turned off... I then turned it of again. AFter that my xbox had no color and all the cables (especially blue) were in place. Can you help me?
    Problem Solver:
  • 10 Answers
Un plug evry thing and then plug it back in if still dosent work i am puzzled
Posted on Aug 26, 2008
When i try to take my Xbox online to download maps for my game it says i need an update downloads update gets to the applying stage and then freezes
  • 1) Turn off your Xbox 360 and physically disconnect it from the internet by either unplugging the ethernet cable or disconnecting the wireless adapter.
  • 2) Turn on your Xbox 360 and sign into your account. You should NOT be connected to Xbox Live.
  • 3) Navigate to the "System" blade and choose the "Memory" option, then select your storage device.
  • 4) Now search. Look through all the system folders then find and delete ALL incomplete content files. You can spot an incomplete file by the yellow exclamation point icon. Remember to delete ALL incomplete files
  • 5) Once all the incomplete content files have been deleted, turn off your Xbox 360.
  • 6) Reconnect your Xbox 360 to the internet by plugging back in the ethernet cable or wireless adapter.
  • 7) Turn on your Xbox 360, connect to Xbox Live and hopefully your problem is solved.
Jul 06, 2011 | Microsoft Xbox 360 Console
Why does my xbox keep disconnecting from xbox live and saying that my sign in status has changed but when i sign back in im still in the party
Check your internet connection...Your internet speed could also disconnect you or lag if it is too slow for xbox live
Feb 02, 2011 | Microsoft Xbox 360 Console
Keep gettin disconnect after 20 min even with fone line disconnected
if you keep getting disconnected then i would do internet test,if theirs no fault your end then i would contact your internet provider,because has long has its not xbox live which i dont think it his then i would ring your internet provider,also let us no more details has in does your internet go down or just xbox live? does your router or modem light go off every 20 mins then quickly come back on?
Nov 23, 2010 | Microsoft Xbox 360 Console
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Problems saving and loading games
maybe the game is a x box live game not a x box 360 game
Dec 27, 2008 | EA Sports Madden NFL 09 for Xbox 360
Staying connected to Live
it a problem with your internet provider i had the same prolem all i did was call them and tell them your being disconnected and the hsould be able to start you up again also tell them if you have a rrouter connnected as well
Oct 20, 2008 | Microsoft Xbox 360 Console
Power went out and back on; now printer won't print
I had the same problem after a resent power outage. Here's what fixed mine.
Turn the power switch off.
Wait a 15-20 seconds
While holding the button on the front panel down turn the power switch on.
After the drum light comes on release the button wait then press the button again.
Turn the machine off then back on again and you should be back in business.
To prevent the problem in the future if you are not using the printer turn it off and if the power goes off while printing get the printer turned off before the power comes back.
Oct 14, 2008 | Brother HL 1440 Laser Printer
Xbox 360 wireless adaptor
the only solution is to buy a new adapter or find a local electronics store to fix it for you!
Sep 07, 2008 | Microsoft Wireless Network Adapter Xbox...
Microsoft Xbox 360 Console Logo
131 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
