Question about Galaxy Radios DX- 88HL Base CB Radio
Superstar 3900 this radio transmits 4 watts of carrier but no mod Im just getting into repairing and would be happy for any advice
    Problem Solver:
  • 9 Answers
3900's do not have a PA mode on them.
Posted on Mar 07, 2009
    Problem Solver:
  • 14 Answers
If you have a PA function on the radio does the mic put out audio, if it does this would rule out the mic
Posted on Nov 05, 2008
Manaul for superstar 3900
Are you looking for the superstar model 3900 or the R.CI. superstar 3900 ?
Jun 24, 2014 | Radio Communications
I have a superstar 3900 black but on am no mod but it keys up fm usb and lsb are fine
check the am voltage regulator. you should have 12vlts on pin 1 ,4volts on pin 2 ,13 vlts on pin 3 . go to ( CB tricks .com ) its the same board layout as galaxy 44 . http://www.cbtricks.com/radios/superstar/3900/graphics/ss3900_sch.gif if you are looking at the board on solder side ,knobs faceing you ,it is located on top left hand corner ,about 1 inch down you will see the slot cut into the board .if you have vlt on pin2 less than 4vlts or higher than 8vlts its bad. Galaxy DX Radios DX44V Service Manual its (tr) 51
Jun 02, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
Tring to wire up sadelta hand mic the mb-4 to the superstar 3900 but dont know the wiring there are 5 wires the couler of the wires are screen white red green andbrown can you help
I would like to state there are two ways to do this, one way is too open the radio cover up and look at the back of the jack where the mic goes and the color of the wires should be the same, or you can do it the second way which is a little longer and patience to do take the wires of the mic and touch one at a time to a prong one should get you sound when its right the other should transmit when you push the handle to talk on the mic
Jun 02, 2014 | Superstar 3900
Superstar 3900 meter not working
Need more info, is the wires soldered on, has one broken, on board do you get a reading an not on meter? Could be meter or poor solder or broken wires. Because you dont get readings at all, tells me its more likely the meter or connections
Mar 23, 2014 | Superstar 3900
Superstar 3900 schematic
First link on Google. Might save yourself a little time and just look for yourself next time...
Bottom of page:
Jan 12, 2014 | Radio Communications
A need help on my superstar 3900 the signal meter does not work on fm (rx) it key's up and stuff and is fine every where els plz email me with help charles_stewart2k9@hotmail.com
The FM has no forward modulation. You're radio will key up but you can't transmit on it. All cb radio are like that after conversion.
Jun 01, 2010 | Superstar SS-3900EGHPA CB Radio
Whats the wiring diagram to connect a sadelta es990 to a superstar 3900
1) Shield 2) White 3) Brown 4) Green
1) Shield/ Ground
2) Audio
3) Transmit
4) Receive
Mar 30, 2010 | Superstar SS-3900EGHPA CB Radio
How do i get more mod out of superstar 121 cb
A super star will only put out around 28 to 30 watts, any more you need a linear, you could have you r swr checked to make sure your antenna is good, any good antenna should talk around 10 miles
Nov 22, 2009 | Superstar SS-121 120-Channels Base CB...
Superstar 3900 with no USB or LSB on receive.
most likely been fiddled with and out of alignment. If you have a freq counter and a volt meter you could possibly fix it yourself. look at cbtricks.com for the aligment procedure.
Jun 13, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Galaxy Radios DX- 88HL Base CB Radio Logo
357 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
