Canon PowerShot SD110 / IXUS IIs Digital Camera Logo
A
Anonymous Posted on Aug 31, 2005
Error 30 I am experiecing an error 30 what can I do?
Anonymous
Level 2:
Sergeant:
  • Expert 255 Answers
  • Posted on Aug 31, 2005
Anonymous
Expert
Level 2:
Sergeant:
Answers
255
Questions
39
Helped
54428
Points
742
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
1helpful
3answers
My Pixma ip8760 experieced a paper jam this morning. Now I get a C000 error code
I moved you to CANON
all printers do that, they love to jam that is there (THING) there bailiwick.
paper dust and chunks land in places not allowed to be there
but guide jams or optical sensors blocked even with paper dust.
If you ask a printer tech this, (mobile) what do the do most the time
they do cleaning endless.
I use shop air here and blow them all out clean as new.
also cleaning up ink smears. using IPA
or use CON_O_AIR , and blow it out.
wash wear clog and repeat. endless printer woe's.
how long did the printer run days,year? before now.????
history matters. (new out of the box?) and this good example.
https://appuals.com/canon-printer-error-c000/
We are getting a F9 code on a GE ZET938 convection wall oven while trying to clean it. What does that code mean?
The wall oven probably has a bad door lock. If the door is stuck shut, average repair cost ~ 300 dollars - 500 Dollars max. Worth calling service if you lack the confidence or experiece to tackle this expensive machine. If the wall oven door actually opens and isn't locked shut, try holding down the door switches to see if you get a response or if the error clears. Recommend calling GE service for this repair if available in your area. 1800 GE CARES
Jan 01, 2019 • GE Ovens
How to fix err,30 on canon t3
Have a look here for error code 30
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/
3helpful
Error 11
ERROR-11, 12, 17, 30 Dirty disc Clean disc.
ERROR-11, 12, 17, 30 Scratched disc Replace disc.
ERROR-10, 11, 12, 15, 17,
30, A0
Electrical or mechanical Turn the ignition ON and OFF, or switch
to a different source, then back to the CD
1helpful
2answers
Error 12 and error 17 only for dvds
iiMesisage Cause Action
30, A0
i hope this answers and solves your problems.
3helpful
Error 12 and 15 what is that
30, A0
Sir,when I am opening my yahoomail, I am getting following msg:Ooops Yahoo. Mail cant load. Loading Yahoo mail failed due to a client side error. Will you kindly advice me what to to do??
i can enter my ID and pass word with any problem but when i click on mail icon to see all the mails in my mail box not thing can be shown. I experieced four or five horizontal line that is controlling the movement of the mouse in which i am unable to access any thing. So please help me.
Jan 12, 2010 • Yahoo Mail
Windows XP Error: category 102 event id 1003
look like a system crash.
try to go into save mode and do a scandisk
if not, remove any newly install hardware or software.
restart the laptop.
2answers
PHASER 7700 ERROR 30
try this
The following functions will generate a Tech Rep Fault:
  • Error: 30: Belt Home Too long
  • Errors: 12, 13, 14, 15: ATC-YMCK Sensor Fail
  • Errors: 40, 44: Fuser Main/Sub Lamp Temp Too High
  • Enter Service Diagnostics
  • Highlight NVRAM Access and press OK
  • Highlight Clear Tech Rep Faults and press OK
  • Highlight the Tech Rep fault to be cleared and press OK
If you have had the error 3 consecutive times , you do need to send the snippet to the printer to clear the error. The instructions how to do it are in the download.
Other things. You may need to replace the accumulator belt.
You may have toner backed up in the waste auger, you can clean that out and replace the waste bottle.
Cause:
The plastic tab attached to the cleaning blade assembly was broken, this tab opens the cleaning blade waste assembly when the belt is lowered .
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. The waste toner from accumulator belt cleaner could not reach the waste bin and jammed the augur. This caused the grinding noise by stalling the accumulator belt motor. This causes an error 30 code to be displayed.
The belt cleaner does come as a separate part 016-1889-00 and is very easy to fit and much cheaper than a new belt assembly.
Error 30 is a Tech Rep fault. After three Error 30's, the NVRAM Clear Tech Rep Faults will need to be reset to be able clear the Error 30 message.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
