Question about Neff U1721 Double circotherm Electric Oven
NEFF U1721 THE FAN IS WORKING BUT THE OVEN IS NOT GETTING HOT, COULD THIS BE THE ELEMENT, ( BOTTOM OVEN )
  • 3 Answers
New element is required.
Posted on Sep 23, 2008
My Neff U1721 bottom oven has just stopped working - the fan still works, although is a bit noisy - what could be the problem/
Sound like the element has burnt out but if your fan is also noisy it is probley running slow which may have caused the element to overheat and burn out so it would be a good idea to replace the element and the fan motor
Regards
Ian
Apr 20, 2011 | Neff U1721 Double circotherm Electric Oven
My neff fan oven keeps blowing it element is there something wrong wit it? I have a double oven and its the bottom one that keeps blowing
It is quite common for neff elements to fail, make sure you have fitted the correct wattage element to it, as there are more than 1 element that will fit it.
Nov 12, 2010 | Neff U1721 Double circotherm Electric Oven
We are just about to have the heating element replaced in our Neff U1721 oven for the 5th time in 2.5 years!. Any answers
Have come across this problem before and it can be cured by replacing the fan motor. As the motor gets older it spins with less power and allows the element to get to hot and burn out. Replace your fan motor problem solved.
Jun 17, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Lower oven not heating up everything else is working fine
hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Jan 18, 2009 | Neff U1721 Double circotherm Electric Oven
Unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double Oven - No Heat
If the fan is running then it is unlikely to be the clock/timer. Yopu need to check if there is voltage to the element but you MUST be careful to avoid an electric shock. There is sometimes a thermal cut out in line with the supply from the thermostat and that would need to be checked. If all OK the thermostat is the likely offender
Oct 13, 2008 | Neff U1721 Double circotherm Electric Oven
Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Apr 18, 2008 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
144 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
