Question about Whirlpool Duet GHW9150P Front Load Washer
Water Shut off
Hot water continues to pour into the machine throughout the entire cycle, even when it is not supposed to.
It sounds like you need a new control valve. the control valve turns on and off the hot and cold water, its electronically controlled so it could be something else but more than likely its just the valve. I had mine go out about 6 months ago, plug and play i was out $30 but that was it.
Posted on Aug 23, 2008
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
LG WM2140C front load washer overflows during drain cycle
This sound like the water is leaking from the drain pump.
Dec 22, 2012 | Washing Machines
I haveno idea how there continues to be water run inside the washer after the cycle runs through. I have even shut the water off and there seems to be water still running inside,
Turn off your hot and cold water valves. Your water valve inside the washer has gone bad. What happens is the valves open and close there is suppose to be a filter screen on both hot and cold inlets where you connect the water hoses to. If not the debris from the water line gets in there and clogs it up leaving the valve open which is causing your problem. Also seen it where people on well water have this problem a lot because the water might be hard with sediment . You can have a qualified technician come fix it won't be too expensive hope this helps and thank you for using FixYa!
Jan 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Water will not stop running
Have you checked the water inlet valve, it sound's like the water inlet valve is stuck open.
Apr 05, 2009 | Frigidaire FEX831CS Top Load Stacked...
Wash cycle water level
the water needed needs to just come up right under the door this is how much water they use cause they use a tumble wash to clean the clothes
low water preasure is a problem but also make sure both water inlets are being used (hot and cold) even if you dont have hot attach a y hose the machine needs both inlets in use
these machines use very low water usage but they still need a fill up point
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De
