Question about Canon PowerShot S2 IS Digital Camera
E18 My camera lense is trying to adjust and just clicks back and forth back and forth until the screen goes black and e18 shows up. Should I take it to a repair shop or is this something that I can fix on my own? A
  • 2 more comments
  • Anonymous Aug 25, 2008
    YES I HAVE THE SAME PROBLEM WITH MY CAMERA.
    PLEASE HELP ME.
  • ESMERALDINA Aug 25, 2008
    I HAVE THE SAME PROBLE WITH MY CAMERA S2IS.
    PLEASE HELP ME.
  • dragonpuff54 Aug 26, 2008
    I have the same problem.
  • Anonymous Aug 29, 2008
    Same Problem here also. I found this link. http://www.e18error.com/repair.html
  • 2,071 Answers
If your camera is still under warranty, the best thing you can dois to take it to the nearest official Canon repair shop and Canon Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Canon refuses to repairit for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Olympus Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Olympus Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Sep 01, 2008
My camera was dropped and now when i turn it on it beeps and then the screen goes black and says e18. i would like to take it apart since i have nothing to lose. do you have anything that shows how to do...
E18 error refers to a lens error .Try checking if any dust got on the lens barrel if not check with the Canon dealer for a replacement as this is might be a factory fault
Mar 31, 2011 | Canon PowerShot A400 Digital Camera
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
May 21, 2009 | Canon Cameras
The screen is black i hear a clicking and moniter says e18
Hi
E18 means you have a mechanical failure it's depend from the zoomunit. If you can fix it by yourself you can clean the small gearbox that is driven the zoom assy sometimes ther is sand or contamination partikels in it.
Otherwise you must replace the zoomunit it's not so expencive.
Regards,
Rob Rotronica
Apr 15, 2009 | Canon PowerShot S1 IS Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
When I try to zoom, screen goes black and "E18" appears in bottom corner
I won't say this is a solution but to prevent the lens retraction E18 message which seems to be common with Canon zoom lenses, I put the extension tube on mine. Sometimes I put a polarizer lens on it but usually I just leave it on to protect the lens when it is on. I have dropped it (on the carpeting at home) and never had a problem. If you have a Canon with a zoom lens, get a lens hood for it ASAP!! My wife's A520 has one on hers too. No problems.
There are lots of other places on the web with suggested fixes. Keep looking and keep enjoying this camera. Merry Christmas all.
Oct 31, 2008 | Canon PowerShot S2 IS Digital Camera
E18
E18 is the canon fault number for lens error. Is the lens stuck out? does it click when the camera is switched on? Try lightly tapping the lens on a hard surface. This sometimes resets the lens. If all this fails take it to bits! (but watch the flash module as this can give a nasty shock.Big black capacitor) You will see the lens module take the it to bits carefully and re seat the components. I have done a few over the years. It takes about an hour. If you have any more issues contact me.
Sep 04, 2008 | Canon PowerShot A400 Digital Camera
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
After E18 fixes...lense got in..but does not come out
You can just head to darntoothysam.com and search for "E:18" without the quotes. You won't see your model listed, but you can buy any one of those model repairs and follow the steps to get your A510 fixed.
Feb 26, 2008 | Canon PowerShot A510 Digital Camera
Screen is showing E18
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
