Question about Smeg Refrigerators
Setting out for the doors on a 70/30 smeg integrated fridge freezer CA330A
  • mark Gidley Aug 23, 2008
    i have a smeg CR330A integrated F/Freezer , i have fitted it into the tall housing unit . i want to fit the kitchen unit doors to the fridge doors . but i do not have the fitting instructions. there are no pre-drilled holes.
    regards
    Genius:
  • 1,269 Answers
Every questions you have about fixing and modifying your fridge can be found at this link:
http://www.repairclinic.com/0088_4_4.asp#Level1_11
hope that helps.
Posted on Aug 23, 2008
  • 6,487 Answers
Try checking this link for your concern http://www.smegsa.co.za/refrigerators/cr330a.pdf
Hope that helps.......
    Master:
  • 848 Answers
Just describe your problem in detail.......
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
Smeg integrated kitchen fridge and freezer unit - freezer stopped
beneath the freezer usualy installed timer and a fan look for a hidden screw on the sides...check the fan bushing f its lose or has a clearance change it f not check for the timer if its busted...replace.. becareful...electric shock can kill
Jul 11, 2009 | Smeg FC40RX Bottom Freezer Refrigerator
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Smeg 50's stle fridge
we had so much frost that the fan couldnt turn to keep freezer cold. we defrosted it and it ran fine. someone left the door not shut all the way and tahats how it got wet and then refroze.
Dec 22, 2007 | Smeg FAB28
SMEG FAB28
This is a known problem with these fridges. The only fox is to replace the fridge.
Jun 16, 2007 | Smeg FAB28
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
108 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
