I daleted my audio device on my computer. now i dnt have sound on my computer
  • Fadia Fouda Oct 06, 2008
    when i go to control panel, and then to Sounds and Audio devices it is show "No Audio Devcie"
    how i can get back my Audio device.
    thanks
No i Can not install form setup disk of my mother board, what i will do know
Posted on Oct 06, 2008
    Master:
  • 441 Answers
Then you need to reinstall the drivers of you audio device. To reinstall it you need to check the brand and model of your motherboard or if you still have the setup disk for you mother board you can install the audi drivers from it.
Posted on Aug 23, 2008
My speaker wont work when i play anytin on internet wit sound i dnt hear a sound from my speakers
1: check the speaker wire. it should connect to a green port at the back of the computer.
2. In control panel open realtek audio device manager. it will tell you where its connected
3. try to configure the speaker from audio device manager on the system tray volume icon
still doesnt work then uninstall the driver for sound card from device manger
restart the computer
Apr 01, 2011 | Computers & Internet
I dnt knw why i cannot hear sound...i have cheked and it is not in mut my pc...plzzz...help me...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 27, 2011 | Audio Players & Recorders
I dont have any sound on my laptop it says no audio output device is installed
ur laptop speakers might not be working properly or ur audio driver was not installed successfully. firstly install audio driver for windows vista.
Nov 11, 2009 | Microsoft Windows Vista Ultimate Edition
Rear and center x-530 speakers won't work
Don't worry, to use a 6ch speaker like yours, first you need to configure your PC sound ports.
  • Go to
  • Control panel>sound and audio devices>press advanced button (the bottom one)
  • Now select 6 channel mode from the drop down list
  • Press ok
  • Now you are ready to go.
  • Now connect your speakers to the three pins on the back panel of your PC.
  • Test with some music now
  • You should here sound from all speakers.
Tell me what happened.
Mar 18, 2009 | Logitech Audio Players & Recorders
My computer have no sound output
i think the audio driver is not installed ...
try installing the audio driver ...
to hear sound audio codecs are required so just install the audio driver given in the manufacture cd while the purchase of the PC or motherboard ...
if already installed then go to control panel > sound & audio devices there you check the audio is it installed or not if it is installed then it will show the volume panel ... if not it will show you no audio device available ...
then you must install the audio driver ... if installed then also facing this problem then go to control panel >system>device manager>check the sound devices uninstall them & then reinstall the audio driver ...
this must solve your problem ...
if still problem persists then check the speakers & wires correctly ...
& check if it inserted to the audio jack only or not ..
check in audio panel is the volume is muted...
if you still persist the same problem then there may be some problem in the port or loose contact check it ...
any doubts you can reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Jul 02, 2008 | Mercury KVM800M Motherboard
My audio card
Hey its is problem with drivers
Please follow the steps to resolve :-
1)Download the UAA drivers first from microsofts site
2) Download the Latest drivers from
http://www.realtek.com.tw/
PCI drivers + Latest Audio drivers
3) windows installed 3.0 / 3.1
4) now go into Add / Remove programs and uninstall the previous version on Realtek drivers also remove windows installer if available
5) now restart your systems
6) Now installe the windows installer first -> restart
7) now install the UAA drivers -> Restart
8) now install the Realteks latest version -> restart
If it does not solve your problems please do reply i have other trick too..::.. :-)
May 30, 2008 | Computers & Internet
Laptop sound
Check Control panel - >System -> Hardware ->Device manager ->sound video an game controllers.and make sure there is no exclamantion mark and also check other devices to see if you require any further audio drivers..
maybe youhave re-install your audio drivers
Cheers!!!
Feb 26, 2008 | Computers & Internet
No sound in system
Check Control panel - >System -> Hardware ->Device manager ->sound video an game controllers.and make sure there is no exclamantion mark and also check other devices to see if you require any further audio drivers..try to left click on the audi link in device mgr and hit update/reinstall.if you have the driver cd make sure you have it in the cd tray before you click update.if still no go post your motherboard model number,i will assist you further
Cheers!!!
Feb 25, 2008 | Intel Premier Resources 4-Channel 32-Bit...
My audio card
Did you install the file you downloaded? Run it then reboot.
Jan 10, 2008 | Toshiba Satellite R15-S822 Tablet PC
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
