Question about Fine Digital FineDrive 400 GPS Receiver
Hi.. pls pls help
Every time I start my GPS it takes me to windows CE screen.. can you pls tell me what needs to be done to get my device back to normal... also seems like map data has been wiped out.. no idea how?.. any help is appreciated.. Thanks ...Ana
    Scholar:
  • 107 Answers
If your original sd card is ok, you can usually run an update program that is on it to restore the system, if not, then your only option is to get my dvd, listed on ebay, search for finedrive dvd.
Posted on Oct 12, 2008
Why does my Nextar gps system takes foprever to load when turn on
If it is running Win CE then it is VERY old. The GPS is probably failing to see the satelites. Probably time to replace it.
Aug 02, 2016 | Nextar w3g-01 3.5"" touchscreen portable...
Hi there im having a tomtom 1505tm and my screan goes black but you can hear in background telling you the road,sometimes i can it opens sometimes no pls some help
Check the power saving features. You may have configured the GPS to turn off the screen display while GPS is reading directions.
Mar 04, 2014 | Tomtom VIA 1505TM GPS Receiver
Can you fix my polaroid mgm 0550 gps that is now a microsoft windows ce can you turn it back into a gps
Hi danpro,
You may try to reset your system (Polaroid MGM 0550) to put it back into gps. You can follow the following steps I have below:
To reset GPS.
1. Go to navigation mode.
2. Press and hold the map button below the display for 5 seconds. Then the GPS resets.
3. Verify that the GPS system is turned on. Touch Menu, Map Options, Settings, GPS Signal.
Hope it helps.
Thank you for using Fixya.
Mar 25, 2011 | GPS
My gps need install windows ce but install because I connect the cable to the computer but the computer gives unknown device message
If you GPS is at the point of needing windows CE installed then it is in a bad way. This is not done in the normal way on the Mitac Mio. It is setup using and SD cardspecific keys assigned by mitac to perform only a minimum of functions for its GPS hardware.LikeRESET +POWER then selecting different options specific to the GPS
Then getting maps on it is also different from a straight install. I suggest you contact MIO and have them reinstall Win CE and the maps for you before you compromise it totally so that it cannot be undone
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Mitac Mio P550 GPS Receiver
MyGuide3000GO: Missing XImage.exe
We can resolve this.
1. you need to download a picture viewer for Windows CE 4.2
2. Need to put it onto the SD card
3.when it done in addons.txt you need to add an extra line with the path.
4. FINISHED :)
Oct 17, 2009 | MyGuide 3000 Portable Sat Nav Car GPS...
I installed the Pioneer AVIC-F900BT and it has been
Windows CE is used to operate the Pioneer AVIC F series, which yours falls into. That version of Windows has not been patched or updated with the new day light savings times and since the player uses GPS to get the current time and Windows to make the time change for your zone then your time will not update until the orginal daylight savings time occurs. You can try to change the time to manual in the Pioneer settings, deal with the wrong time for just a lil bit longer until the original Daylight Savings Time takes place, or re-search an update and way to update the players OS which is Windows CE. Hope this helps :)
Mar 10, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
Finedrive 400 DVD
I have one on ebay almost all the time, was on vacation recently but I am back...
Aug 19, 2008 | Fine Digital FineDrive 400 GPS Receiver
A problem with My FineDrive 400
You may actually have more than one issue. the startup issue may be solved by reloading the firmware if its just that but if your unit has other damage you may not be able to recover it. try booting with the home button held pressed, this should take you to windows ce. if it does then you may have a chance. the calibration for the screen can be done once you can run the unit but not gettign a fix could be even a faulty antenna.
I created a dvd with the firmware and map data upgrades, its on ebay if you search for finedrive dvd. its way cheaper than what fine digital used to sell similar dvds for.
Apr 30, 2008 | Fine Digital FineDrive 400 GPS Receiver
Mio gps touch screen not responding
How do i calibate my address menu on my garmin 2620 when I try to push a 1 the 2 pops up etc
Apr 18, 2008 | GPS
Open Questions:
Fine Digital FineDrive 400 GPS Receiver Logo
67 people viewed this question
Top Fine Digital GPS Experts
ChuckyMo
drivealot
Iqbal Husain
Iqbal Husain
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
