Kenmore washer model 110.24642300 fills with water and then does nothing. Tried other modes such as spin, but it stills does nothing.
I had the same problem.
The sensor which determines whether or not the lid is down may be going bad.
To tell - turn the washing machine on and let it fill with water. At this point, the washing machine stops. So raise the lid and place a screwdriver into the hole around the collar of the washing machine. This is the same hole that the lid, when closed, presses into, activating the sensor to notify the machine that the lid is closed so it can begin washing.
Posted on Apr 19, 2009
This was posted 4 years ago, but it just saved me over $40 at the Appliance repair store. my 110.24642300 would fill with water and do nothing else, I removed the broken, visably broken lid switch and simply cut and soldered the 2 outer wires (both black) together and hooked it up like that and it fixed the problem. If you have small children in the home around the wash machine at ANY TIME you should fix it properly. My kids are in the late teen years and know not to reach into the tub while moving. I hope this helps somebody, I know I appreciated the help
Posted on Sep 04, 2012
huuum
  • 750 Answers
SOURCE: KENMORE 110 -LETS WATER IN..DOES NOT SPIN
Hello Sylvia,
You said,
HELLO...I HAVE A KENMORE 110 WASHER, LETS WATER IN BUT DOES NOT SPIN. PLEASE HELP. SYLVIA
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin.
The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts.
If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed.
As the clutch wears out, it may prevent the unit from spinning well or at all.
If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor.
For agitation the motor runs in one direction, for spinning and draining, the other.
It's possible for a motor to burn out in one direction and continue to operate in the other.
If this happens, you need to replace the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool®
have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective,
the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized.
These components allow the inner tub to spin freely inside the outer tub. When this is the problem,
you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety,
washing machines are made so that they spin only with the lid closed.
The lid switch prevents the spinning action when the lid is up."
Bless You,
Please give me a good rating for the sound advice , before you sign off.
Thank You
Posted on Sep 17, 2008
aborcass
  • 2651 Answers
SOURCE: won't spin out water
sounds liek you have a bad clutch assy, not engaging fully, tip the machine back and give a look around teh inner perimeter of the cabinet, do you see brownish oily streaks dripping down, perhaps a pool of oil under hte unit??? if so you need a new transmission(5 year warr) and clutch assy
Posted on Mar 23, 2008
reg501
  • 413 Answers
SOURCE: kenmore washer 24642300
The lid switch has failed. To replace lid switch;
REMOVE POWER, lift the console by removing the trim on either side. Grasp the top of the trim and pull forward to expose a screw. Remove both screws and lift console.
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The lid switch can now be accessed and replaced.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 05, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore 110-24632300
This problem is commonly attributed to a lid switch malfunction. The lid switch is mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
A replacement lid switch can be purchased on line at appliancepartspros.com for about $25. The part number is 3949238. Just use the "Search by Model Number" feature when you go to the site. If you do not wish to order on line, take the part number provided to your nearest appliance parts retailer. This is a very common part that they should have in their inventory. For instructions on how to replace a lid switch, you can refer to this link: http://www.fixya.com/support/r385198-replacing_lid_switch If you still need assistance, please contact me and let me know. I hope you find this information helpful.
Posted on Apr 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 70 series washer fills w/H20, but doesn't agitate or spin
Fix it. Very easy fix and the part is not expensive. What you have is a direct drive motor. For ease of maintenance the machine is made in a way which makes it possible to service it in place without having to move it. You flip the controls up and pop the retaining clips in back, unplug the lid switch harness and tip the case towards you an out of the way. You can now access the pump, motor, and that pesky drive coupling. These do simply wear out but they usually will go if a comforter is washed in it or low water big load scenario.ea74271.jpg
I have videos repair manual,parts locaters and repair photos: HERE
Posted on Feb 14, 2010
Testimonial: "Thank you for the EXCELLENT & QUICK solution! Your repair suggestion along with instructions worked perfectly & saved us hundreds of $$! "
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
I filled my washing machine with clothes tonight and it got to the end of the short cold wash cycle and had stopped running so I pushed in the knob then pulled it back out and then pushed it back in and...
It sounds as if the machine doesn't spin during the spin cycle. Normally the agitator stops spinning, fairly quickly, if the lid is opened during the spin cycle.That safety circuit includes a switch mounted under the opening and is set by a tab on the lid that protrudes thru a small hole in the top of the washer. The most likely failure on most Kenmore models is that switch, broken or loose, the tab on the lid broken, or the two misaligned. I would need the model number of your washer, located on a tag on the bottom of the lid to be more specific
Jan 07, 2010 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
906 people viewed this question
Top Washing Machines Experts
