Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore washer has smoke smell, now won't turn on
Noticed electrical-type smoke smell coming from Kenmore washer. Then noticed cycles were starting and stopping erractically. Now doesn't turn on at all. Checked lid hinge and it is ok. Checked for circuit breakers and they are fine. Checked power cable to wall socket and to washer and appears fine too.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
I have a Kenmore Oasis Elite 110.280442700. I bought it at the beggining of 2008, never has given me any problem. About a month ago, it started to make a really loud noise during a spinning cycle, as if it...
April, You say you are suspicious that the smoke could have originated from the motor, BUT have you confirmed it? Have you tried running a short cycle without a load to see if the spin cycle rattles the machine or whether the machine works? Watch for smoke and turn off the machine immediately if you see or smell burning. If the motor is burnt, I think replacing should not be an option but rather replacing the machine should be considered.
Mar 01, 2014 | Kenmore 22642 Top Load Washer
My wife noticed smoke right after starting the washer. She immediately turned it off and called me. I noticed a smoke smell which smelled more electrical than rubber. The basket spins easily. The washer...
Thanks for choosing FixYa and welcome to the site. There are a few things that you can check. First, check your belt. It may have worn or the pulley may be sticking. The belt may be causing the smoke. You might want to check your control board just in case and see if you see any damaged wires. You need to try and see if the washer throws out any error codes. I really don't know what else you could check because there are no symptoms. It could have come from the water pump or the motor drive also.
Apr 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 80 series washer control dial.
Hi Bill,
Glad you came here and I'm glad I did too!
The timer is most likely the source of the smell. remove the two screws on the front of the head to pull the head back, see if you see any charing on the wires going to the timer or is it just the timer that is smoked? if the wires are charred, you would need to replace that entire harness.... not sure you can get one, but if you can! :) Same applies to the timer. Explore your options before just chucking it all. Maybe a used appl. dealer will help you out. As long as it doesn't leak or have a major defect, I agree with repair before replace. Good Luck, let me know how you make out
Aug 25, 2009 | Kenmore 24902 Top Load Washer
Humming from Water Solenoid area
It may have some dirt or sediment clogging it making it work harder than usual.
Jan 23, 2009 | Washing Machines
Kenmore Model 24642300
It is usually a coupler, look under to see if black shavings
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Burning Smell
no check wiring connector at the motor and the capasitor connectoions, lid switch connections
May 10, 2008 | Washing Machines
Smoke smell coming from my 80 series Washer
do you actually see smoke or is it you have a burning smell
if you have a smell the motor may be overloading on spin
sometimes this is due to too much soap powder in wash
and when machine spins the water cant get away due to soap suds under and around bowl
acts like a brake on motor
try no soap powder in next wash
a good way to tell is that you still have soap in washing if you lift the lid (with no soap powder added)
Dec 02, 2007 | Kenmore 15864/15862 Top Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
324 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
