Question about Whirlpool Duet GHW9150P Front Load Washer
Fault code 06 whirlpool duet
Checked all wires checked good went throuh dianostics check good why is this happening
  • Anonymous Apr 10, 2009
    Not so helpful for the do-it-your-selfer!
  • 639 Answers
Dear jehurtknee
ngfam at you service!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
How do i reset a dryer display when i get the fault code F 06 on this machine Whirlpool AZB8670 ??
it's not normal for this to happen but you might have to get someone with a computer to reset it for you ask an engineer to check for you
Jan 03, 2015 | Whirlpool Washing Machines
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F11 error - Whirlpool Duet washer
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2P3BOEFKI
you'll need to call someone in on this one,boards are very expensive and like it says it names both the ccu and mcu boards or the motor,if you call say whirlpool they might give you the part but you pay for labor and they will have the boards on the truck,the guy will replace one board at a time to see what one is bad,not like the older machines that you can check the parts with a meter.good luck
Mar 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet is giving me a "F/06" error. It
F/06 is a tachometer error for the drive motor This error code is a very difficult to diagnosis unless you are their in person to check the many things that need to be checked to properly diagnosis this concern. It involves checking the drive motor and tachometer the motor control board (computer) the machine control board (computer) ,and all wiring harness in between in other words this is where you need a highly qualified tech for a proper repair unfortunately. Of the one's I have diagnosed 80% were the drive motors the tach is made onto the motor and is not available separately,THE OTHER 20% where all the other items i mentioned. I truly wish I could help you more but this error is one that needs hands on testing and anyone that tells you different is incorrect and would just be guessing ..But if you want to try you can get a motor for about 165.00 and the motor control board is about 230.00 the good thing is you wont need both and if it's wiring you wont need either one. SORRY I could not help more Good Luck
Nov 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stopping and flashing F 06 fault
F/06 ---- ERROR IS FOR ----------- Drive Motor Tachometer ErrorThe control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.----------
AND TO SOLVE THIS ---------Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) --
Check the Drive Motor
Check the MCU
Check the Wire Harness
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT GHW9300PW4 F 06 Error Code
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Mar 25, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GW9200L Keypad / Diagnostic test shows code 06
troubleshoot whirlpool duet dryer GW9200 Press the start button and the beeper sounds once and you hear a relay trip but nothing happens. Did a diagnostic / keypad tes and the code was 06
Feb 07, 2009 | Whirlpool GGW9200L Gas Dryer
Whirlpool Duet F 06 Error
Remember that you don't want to do anything that would jepardize your manufactures warranty on parts and labor.
Nov 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
