Question about HP Xb3000 Notebook Expansion Base And 400gb Kit 400 GB Hard Drive
HP Expansion Base
You suggest that it looks like a power problem on the right side of the board.and I can reset the connectons on the internal board. How do I reset the connections?
  • 1,031 Answers
CHECK THE CONNECTORS ON THE BOARD,FOR POSSIBLE LOOSE END.
Posted on Aug 23, 2008
I have motherboard Compaq #277498-001 and can't find power sw
Not sure of your particular MB, but most always the switch is a pair of pins in an array where the front panel LEDs and reset and power switch are.
This array of pins is almost always at the lower right hand side of MB. Assume the components side is facing you and the expansion slots are at your left hand, (where you add extra cards like video etc). then look at the lower right side or bottom edge, mostly right at the edge of the board. Should be an a double row of pins, at least 8 maybe up to 12. Look real close next to these and you may see print indicating which pair do what. PS = power switch. RS = reset, HD = Hard drive LED PLED = power led light.Spk internal beep speaker etc. (Note LEDs require correct polarity to work) Sometimes no print there.. Then you need the manual to decipher pin pairs. Or experiment. All you need to do is make the connection momentarily (like push button) with a small screw driver tip to start it, while looking for correct pins.
If no power on check your power supply connections on the MB. Or suspect either MB or Power supply issue.
Mar 24, 2012 | Compaq ( 277498-001) Motherboard
Hp Xb3000 notebook expansion base
if you remove Mb battery for few min it will get reset
Aug 23, 2008 | HP Xb3000 Notebook Expansion Base And...
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
How do i turn my lap top microphone on or do i need to plug one in regards mike
Hi Mike,
The spec say it has a built-in microphone. If you are using Windows, open the sound controller and check that the slider on the microphone is turned at least half-way up. When you open the sound controller (speaker in the systray next to clock), the microphone is normally muted. To test, unmute and tap the microphone or speak into it. Make sure you have the volume turned up on the speakers too.
The dv1000 notebook is equipped with:
  • 1 Type I/II PCMCIA card slot. I store my Media Remote control. (left side)
  • 1 IEEE-1394(Firewire) (right side)
  • 3 Universal Serial Bus (USB 2.0) (Two on the right side and one on the left)
  • 1 Built in 6-in-1 digital media reader (No Compact Flash)(Right Side)
  • 2 headphone-out (front)
  • 1 microphone-in (front)
  • 1 TV-Out (S-video) (right side)
  • 1 RJ-11 (modem) (left side)
  • 1 RJ -45 (LAN) (left side)
  • 1 External VGA monitor port (left side)
  • 1 expansion port for use with HP Expansion Base(sold separately). Available only with Intel Extreme graphics with productivity port (left side)
  • Power jack (in the back)
  • CD/DVD drive (right side)
Jun 01, 2011 | HP Pavilion dv1000 Notebook
I have a HP Pavilion Computer and a HP xb3000 expansion base. The base doesn't seem to work anymore, including the extra USB ports or speakers. It appears that only the power supply through the base to...
they are now obsolete.
there is no support on them now.
HP zero
no books
no schematics
nada.
they call that legacy stuff now, and everyone cringes at the thought.
why not ask HP actual
let them cringe.
the base only works on the data sheet listed PCs. (we have that)
you never said which one. you have (if you cheat this, it works 1/2 way or not at all or fails randomly, )
https://h30434.www3.hp.com/
Aug 03, 2017 | HP Xb3000 Notebook Expansion Base And...
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
How to connect power led ,HDD,Reset,power SW cables in hp motherboard s/n 383620-001
check your motherboard manual if you do not have it go to www.support.hp.com and look for manuals based on the model. this should give you detailed instructions as to which pins you plug those cables into. usually they are located towards the bottom of the motherboard to the right of your PCI Expansion slots
Aug 20, 2008 | HP Computers & Internet
HP Xb3000 Notebook Expansion Base And 400gb Kit 400 GB Hard Drive Logo
234 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
