I have a service call into GE for a repair but keep seeing comments that it is easy but time consuming to replace. Can you provide me with the steps to relace the top or direct me to a site that can? Thanks for your help!!!
My GE Profile Cooktop as a clicking swound when not in use (the clicking sound stops when I pull out...
(More)
My GE Profile Cooktop as a clicking swound when not in use (the clicking sound stops when I pull out thr electric plug from the wall. The clicking is when you turn on a burner to cook something. Can you help me Peter
We use LP gas. The two left hand burners have so much gas pressure that 1/4 to 1/2 of the flames go...
(More)
We use LP gas. The two left hand burners have so much gas pressure that 1/4 to 1/2 of the flames go out. The right hand burners are fine. I can adjust the individual low flame but do not know how to adjust the individual high flame. Any help would be much appreciated.
how do I remove the burner base to clean the gas orfice? The flame on the large burner will not...
(More)
how do I remove the burner base to clean the gas orfice? The flame on the large burner will not adjust to high flame. i believe ther is dirt clogging the orfice.
On a GE jpg989 four burner gas cooktop one igniter has failed. I can se it is not sparking on...
(More)
On a GE jpg989 four burner gas cooktop one igniter has failed. I can se it is not sparking on ignition. Have located the part but not sure if this is an easy or difficult job. How would the igniter be changed??
