Question about GE WJSR2070B Top Load Washer
Constant draining I don't know the model # or can even find it , however just today when I did a load of clothes I noticed that the washer drains constantly no matter what mode it is in. A valve problem perhaps or maybe a selenoid?
  • 5,911 Answers
You may have a simple problem known as "siphoning". The following link explains this to you and how to correct it:
Double check you installation and make sure your drain line has the proper air gap. This is the most common source of this problem. If you read through the link and still have a problem, please let me know. I hope this helps you.
Posted on Aug 23, 2008
Washer leaking from bottom
If this is a front loader, you can take the front panel off under the door and inspect the bottom of the machine, there is a drain and trap with a large plug and the pump. Both need to be inspected and the drain should be cleaned and the debris removed from the trap. Get ready for lots of water though if you take the cap off the drain.
Feb 17, 2014 | Haier Washing Machines
Won't drain properly
Hi Brian ramsden,
So i understand that your washer is not draining properly even after replacing the pump. It drains without clothes but when clothes are in the appliance it will not drain. I suggest that you contact the manufacturer or you local authorized technician for more information and assistance. This way they can get to the root of what is causing your washer to not drain properly.
-Best Regards-
Jan 14, 2014 | Frigidaire FTF530FS Front Load Washer
I have a 4 year old Kemore HE2 that isn't spinning the water out of the clothes. I encountered this issue about a month ago and found a fix for cleaning out the hidden pump trap. After removing a large...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
Washer does not spin out all of the water & we
The symptoms you have are constant with a clogged drain hose or drain pump.
Try draining as much water from the washer as possible. Then take the drain hose off the machine take it outside and run water through it. If this is clear, tip the machine up and take the drain hose off that is inside and do the same, this drain hose connects directly to the pump in front. When you have the hose off look to see if something is in side the pump like a sock.
Jun 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a top load GE model #WBB4500G, and our clothes comes out smelly. It is horrible. We are constantly having to rewash clothes, this is rediculous. I've heard of this problem with front loaders, but we...
You have an inner and an outer tub. The outer tub may be holding too much water. The smell may be the soured water in the outer tub. You should take the washer outside and drain it completely. Then replace the drain hose before you put it back inside. Hopefully, this will slove your problem.
Sep 04, 2009 | GE WSXH208A Front Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE Washer shaking
Check this first: level of machine and all feet secure. Is the machine on a pedestal and is it securely fastened? Are your clothes wet after a spin? I know I stress drain height and hose placement, but todays washers are power misers and this means smaller motors. A pump needs some give at the drain, a slight gap like an old dishwasher so it can pump easier. I feel some water is in the machine and not draining in time causing a vib during spin.
Jul 11, 2008 | GE WBVH6240F Front Load Washer
Shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Apr 19, 2008 | GE WBVH6240F Front Load Washer
GE WJSR2070B Top Load Washer Logo
60 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
