Question about HP PSC 1315 All-In-One InkJet Printer
Test paper whenever I turn my printer on it gives me a test paper which is a waste.
  • dunning Aug 28, 2008
    I have installed both ink cartridges,now when I try to print,it prints the test sheet every time,then it might print or it will not.I have tried cancellingthe print demand,however it cancel all but one showing deleting,the when I am doing something else it might start printing.????
  • magpag Aug 29, 2008
    I have the same problem. Every time I issue a print command the test page prints out first!
I had this exact problem after replacing the Black Ink cartrdige.
Tried many things but nothing worked.
Eventually found the instructions below on a differnt forum and now the problem is resolved.
Hope it helps you guys
qoute:
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
of course I had to get the scanner working first as that was an other issue I was having
Posted on Aug 31, 2008
  • 29 Answers
Can only think that if the printer has a menu screen there may be an option to turn off that function. If it is only happening when you use it within office software...that the option is there to switch off the function......more often than not that is the case.
2 Suggested Answers
rakeshpramod
  • 234 Answers
SOURCE: HP psc1317 printer - wasting paper on power on by printing test paper
If the alignment is not done sucessfully then the printer prints a test page every time the printer is turned on, so it is recommended to align the printer and the cartridge.
Try th steps again in the bellow link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00109818&dlc=en&product=374568
Good Luck
Posted on Sep 01, 2008
Whenever I try to print something I keep getting
It's a possible hardware issue in the feeding mechanism. Try to remove the cartridges from the printer then close the cover. Remove the sheets of paper. Unplug the printer from the power source. Wait at least 30 seconds before plugging back the printer to the power source. When the printer's ready, reload the cartridges. Load some paper but don't overload as this may send wrong information to the printer. Have the paper guides lightly touch the sides of the paper, thus avoiding shifting of paper when it feeds. Let it print an alignment page and do some test prints from computer. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 25, 2010 | Lexmark X4270 All-In-One InkJet Printer
Question re: test page
i have this printer, what you have to do is when you power it up, wait and listen until the printer grabs the paper to do the test print, then quickly press the CANCEL button once, the paper will pass through the printer but not print, then just put the paper back in the feed tray and start your day with a smile. The cancel button is on the left hand side underneath the power button. The printer prints a test page when you change ink cartridge as well by the way.
Apr 26, 2010 | HP PSC 1350 All-In-One Thermal Printer
Dell photo 864
You might need to speak to Dell or a specialist repair shop.
Until then, please, if wasting paper is the 'only' problem why not just start if up with a piece of waste paper in the feed?
Come to that, why not leave it switched on? Of course that will waste a bit of power but that's not likely to cost more than the power or the ink it wastes on testing itself every time it's switched on...
Nov 29, 2017 | Dell Photo 964 All-In-One InkJet Printer
After turning on printer, prints initial "blank" sheet
You can fix this by turning off bidirectional support:
- Right click your printer, select properties
- go to the ports tab, uncheck Enable bidirectional support.
Your printer has to be turned on before printing.
That fixed the extra page printing S1M problem for me.
Oct 11, 2009 | HP LaserJet 4 plus Printer
My printer needs to have the waste ink reset how do I do this
You can try this....
  1. Turn off Canon S300, S400, S9000 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon S300, S400, S9000 Printers should respond as normal.
But this happens because the waste tank is full. You need to locate it and use a paper towel to absorb the waste ink. Whenever the printer cleans itself ( when a new cartridge is installed, for example) some ink is cycled into this chamber. So if you reset and it is full, overflow may occur.....
Jul 23, 2009 | Canon BJC S300 InkJet Printer
Alignment page prints every time I turn on the printer. This just started when I installed a new black cartridge. It's totally wasting my ink!
plz give print test page and after printing the test page you have to put the print paper in the scanner and push the scan button
Jun 25, 2009 | HP Photosmart C3180 All-In-One InkJet...
Every time I turn on my printer, a Dell 948, it prints a page
Hi
We have 30+ printers... which we use for testing empty inkjet cartridges prior to refilling with ink. Basically we inject a little Magic Inkjet Flush directly into the dried print head which allows us to unclog them. Then we soak them overnight on Magic Pillows which gives just enough to do a PRINT TEST next day.
As some of our printers always try the alignment test here´s what we do...
1. Pull paper stack slightly away from printer, when it tries to print it thinks it is out of paper and should offer a cancel print option.
2. Alternatively if you print daily? Try leaving your printer power on... Some do alignments every time you power up... so dont switch off (they use very little power in standby.)
3. When exchanging inks like HP immediately switch off printer which cancels the print test. Then just switch on again.
4. Reinserting your printed sheets each time will save paper if not ink.
Good Luck!
Tinteiros (Ebay)
Mar 22, 2009 | Dell 948 All-In-One InkJet Printer
My hp printer 5610 all-in-one does not turn on. What to do?
whenever i press the 'on' button, my printer doesn't respond.
Jan 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Noisy operation and black marks on left side of printed paper
vacuum out the waste toner passages that lead from the drum and transfer belt to the waste toner container. Toner is building up inside the transfer belt and/or drum and has no place to go except onto your paper.
Nov 06, 2008 | Samsung CLP-510 Laser Printer
Good Luck
Aug 31, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
69 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
