There are two things to check if the phone does not take a charge, even on a new battery.
Try to check if the charger is okay by trying it out on another phone, if it is okay, then you do not have a problem with the charger but if it is not, then it need to be replaced.
Then the connection port on the phone is to be tested, and to test that, what you have to do is try to try a well tested okay charger on it to see if it will work, if it does not work then you need to replace the connection port on the phone.
That is the simple way out of the problem.
Hope this helped.
Goodluck
Elect_Comp
