Question about Black & Decker 9072CTN Cordless Screwdriver
My cordless Black & Decker Pivot screwdriver, stopped working. It is completely charged, but will not work.
    New Friend:
  • 55 Answers
Most likely it is the switch has gone bad or just a loose connection on the switch . you can take it apart and check the switch connections and make sure they all have a good connection.If they do then you should take a volt meter and make sure that when you puch the button they get proper voltage if not then order a switch and replace it .
Posted on Dec 05, 2008
New dp240 screwdriver wont charge
Take it back and get a Makita or Millwauke Tools cordless screwdriver of at least 14.4V. B&D isn't what it used to be! Neither is Ryobi!
Dec 08, 2013 | Black & Decker Pivot Plus Cordless...
I have a black & decker pivot plus that will not charge. How do I know if I need a battery or if I need a charger?
Batteries are only good for about a year, if they are older than that, take them back to the store and see if they are guaranteed at all, (all Ryobi tools and batteries have a date code on them, and they are all guaranteed for 2 years, a little plug for Ryobi,) that is all I buy now days, they work great. So, to check your charger, you will need a volt meter set on 12 or 20 v dc, and see if the charger is putting out, if not, then, the cost of a new ryobi might be the same as the fix for the black and decker. That is if you use the thing, we use our cordless tools every day and charge them every night, hope this helps.
Jun 28, 2011 | Black & Decker Pivot Plus Cordless...
How do you turn it on?
Click on the link below to access the Black & Decker Pivot Cordless Drill/Screwdriver owners manual, inside this manual will show you how to turn it on:
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/5145342-00,PD600PD600G.pdf
Feb 04, 2011 | Black & Decker Pivot Plus Cordless...
I KEEP MY PIVOT ON CHARGE BUT IT DOES NOT WORK
if you know how to use a volt ohm meter you can check your charger, battery and switch.
Aug 29, 2010 | Black & Decker Pivot Plus Cordless...
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Apr 08, 2010 | Black & Decker Pivot Plus Cordless...
Power is low. How to charge it?
The pivot has to be in the straight position and the charger plugs in the joint (it's hidden in the bent position)
Mar 19, 2009 | Black & Decker Pivot Plus Cordless...
this one dosn't charge. It takes batterys. how do i change them
Dec 20, 2008 | Black & Decker Pivot Plus Cordless...
Black & Decker Pivot Plus Cordless Drill/Screwdriver AC Adaptor
extend the handle straight and all will be reavealed! Just in front of the triger inside the piviot point.
Mike
Nov 13, 2008 | Black & Decker Pivot Plus Cordless...
Black & Decker 9072CTN Cordless Screwdriver Logo
485 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
