Question about Nikon Coolpix 5000 Digital Camera
Cannot connect Speedlight to SK-6 Power Bracket
I cannot connect my Nikon Speedlight to the SK-6 Power Bracket. The connectors do not fit?
    Novelist:
    Scholar:
  • 79 Answers
A change was made in the flash power connector on later Nikon Speedlights and the Power Bracket Model SK-6. It is impossible to connect a flash with the older (square) connector to a newer SK-6 or vice versa. The flash on the left has the older square-style connector, while the one on the right has the newer connector. Both the Speedlight and the SK-6 must have the same style connector. Please contact Nikon Service about having the units modified for compatibility.
Posted on Aug 30, 2005
2 Suggested Answers
SOURCE:
  • 79 Answers
SOURCE: Cannot connect Speedlight to SK-6 Power Bracket
A change was made in the flash power connector on later Nikon Speedlights and the Power Bracket Model SK-6. It is impossible to connect a flash with the older (square) connector to a newer SK-6 or vice versa. The flash on the left (above) has the older square-style connector, while the one on the right has the newer connector. Both the Speedlight and the SK-6 must have the same style connector. Please contact Nikon Service about having the units modified for compatibility.
Posted on Aug 29, 2005
Nikon d 90 camera Nikon Speedlight SB-600 TTL Flash on auto flash fire when dont any photograph when ready red light on
This sounds like there may be a short in the control circuit that senses the flash command. First check the wiring and the circuit area where the connector feeds. check to see if the connector circuit is shorted. These are some of the basics. It could be the internal circuit board is shorted.
Apr 25, 2014 | Nikon Speedlight SB-600 TTL Flash
Loose in hot shoe
Have you tried to tighten the little screws on the hotshoe?
if not you can purchase an off the camera flash mount
Multi-Flash Bracket Unit SK-E900
May 20, 2011 | Nikon Speedlight SB-800 TTL Flash
I have a Nikon D40x with a Nikon Speedlight SB-800. The speedlight is not working. I have the camera on, new batteries in the speedlight and speedlight on. Not powering up. Is there some secret battery...
With new batteries in the flash, and it being off camera what happens when you press the test button. If still it does not flash call Nikon 1-800-645-6689
Aug 14, 2010 | Nikon Speedlight SB-800 TTL Flash
I have a quantaray qtb-7500a speedlight. It is for a Minolta camera. Is there any way to adapt it to fit Nikon equipment? jim
There are modules available to convert the camera into a Nikon lens. Right below your fill flash on the left hand side of the unit, there is a square button to release your current module and attach the new Nikon module.
May 20, 2010 | Quantaray QTB-7500 for Nikon TTL Flash
Speedlight SB-22S TTL Flash: i have a Nikon Speedlight SB 22 that was used on m...
sorry ,you will have to get a flash for digital.nikon dx type.film flash not compatible with digital.
May 17, 2010 | Nikon Speedlight SB-22S TTL Flash
Nikon D70s will not shoot
Make sure the hotshoe is clean, this will give the hotshoe a better connection. Make sure you lock the speedlight into place.
Oct 08, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon speedlight sb-800
THE PROBELM COULD BE IN MAIN BOARD OR THE BATTERY CONATCTS NEED ADJUSTING
Sep 22, 2008 | Nikon Speedlight SB-800 TTL Flash
How do I connect the Nikon SD-8A battery pack to the SB-800 Speedlight?
The sb-800 has a connector on it marked "HV", this is where the sd-8 connects.
May 16, 2008 | Nikon Cameras
Does Nikon D70 come with an additonal bottom to plug in Bowen Flashfill
Are you using the built in speedlight on the camera with the lens hood fitted? If you are this will cast a shadow. Try removing the lens hood when using the pop up flash.
Nov 27, 2007 | Nikon Speedlight SB-600 TTL Flash
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5000 Digital Camera Logo
211 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
