Question about HP iPAQ RX3715 Pocket PC
Sat nav information deleted
Hi, i've got ipaq pocket pc 2003 pro model; seems taht i've left it on witout charge, and it lost sat nav information. cannot find manual... can you help please to reset sat nav..???? thans Olga
I`m sorry no ingles. mi problema es no conecting Microsof
activesync information windows (No se encuentra punto deentrada del procedimiento CeSvcOpenW en la biblioteca de Vinculos dinamicos CEUTL.dll) please solution problem
tenquiu
Mi Naime.Luis Carlos Ibarra Lopez
Maill.- luis_cil59@hotmail.com
Tel.(871)7330269
Posted on Aug 29, 2008
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
I have a manual hp ipaq pocket pc 2003 pro w/outlook 2002
Early versions don't charge through the USB cable. They need a separate power connection. You'll need to buy a power cord.
Jun 12, 2009 | Microsoft Windows Mobile 2003 for Pocket...
HP Ipaq 2410 screen alignment
relic, what good is this device?
why not ask HP , where if lucky , some one there can even remember that long ago.
its 14 years old. has zero value , seen in garage sales for $1
and no buyers.
why you? sorry but what good is it?> there is no service now.
my advice? is to dump this and buy a used real cell phone for $5
and work on that, work on something with a future and not this device IPAQ anything.
now here is real HP , this is not spam nor jackers or the like,
its the REAL DEAL, the maker of you DEVICE.
HP
https://h30434.www3.hp.com/
Nov 26, 2017 | HP iPAQ HX2490 Pocket PC
Sat navscreen
ON :
http://search.stores.ebay.ca/ElecRealm_rz1710_W0QQfciZQ2d1QQfclZ3QQfsnZElecRealmQQfsooZ1QQfsopZ1QQfsubZ7567856QQsaselZ441440394QQsofpZ0
you wil find a drop in replacement for the IPAQ
i did this twice before you need some knowledge of eletronics an for the rest just common ceense .
good luck
Apr 28, 2008 | HP iPAQ RZ1710 Pocket PC
Power socket / plug.
Hi, If you search the web for ipaqrepair, you can buy the connector for just over a tenner, and solder it on yourself (If you´re brave!) or the circuit board is available for about 55 quid.
It looks like they can repair it for you too, if you ask for a price
Dec 25, 2007 | HP iPAQ H5550 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
385 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
