Question about Motorola Cell Phones
Pins where the battery connect on the motorola v3 phone are broken
Its now ok thank you
Posted on Aug 24, 2008
When iam charging my phone, its saying the invalid battery message
Usual cases like this is just a battery problem,try to replace an original one,also check the battery terminal (4 pins) connected on the board if it's align or level.
thank you for visiting fixya.
Jun 14, 2011 | Motorola Mobility RAZR V3
I cant connect my motorola in computer using USB
the problems may come from:
1 your USB lable is broken, try a new one
2 your V3 usb interface is broken
check it by yourself, hope this will help you.
www.eshopbing.com
Sep 28, 2009 | Motorola Mobility RAZR V3
I am getting a random error message on my Motorola RAZR V3 Celluar phone. It says I should insert the SIM. The message goes away when I reboot, but it reappears. Can anyone help?
Remove the back cover, battery and SIM card. Wipe the SIM and the pins where the SIM card is inserted with a cloth if u can. Reinsert simcard, battery and back cover.
Aug 24, 2009 | Motorola Mobility RAZR V3
My phone tune itself of
Try cleaning the contacts on the battery and pins that connect to the battery
Aug 03, 2009 | Motorola Mobility RAZR V3
Retrieving data, broken screen
hi
The Phone needs a new Keypad flex and most likely a left hinge pin. When the phone is open, the cable runs through the left side of the hinge. It is very common for the hinge pin to become chipped and put a small cut in the Flex Cable.
You can get the parts on ebay. search for motorola v3 keypad flex, and motorola v3 hinge, or knuckle.
thankyou.
May 04, 2009 | Cell Phones
Network pin blocked
here is the procedure .
1. power off phone
2. connect phone to cable (for w220 you can use Cable with "X60" mark (Hands-Free cable with 3 metal pins) or ordinary Moto T191 cable).
3. press "Prepare" button and power on phone
4. wait several seconds
5. remove/install battery
6. power on phone
7. press "unlock" button
8. you see unlock codes
Jan 06, 2009 | Motorola Mobility RAZR V3
Screen goes blank before i can key in pin number
have the flexcable replaced and try also a new battery
Dec 27, 2008 | Motorola Mobility RAZR V3
Battery
sometimes it happen when you accidentally drop your phone but most of the time there is some loss parts inside ... try to check the pin connecting to the phone & battery and if you dont know how to do it just go to the nearest phone repair shop to fix it for you before you change the battery......!!!!
Apr 08, 2008 | Motorola Mobility RAZR V3
Broken backlight
if you open the v3 phone flip...you shall see 4 rubbers...remove the rubbers with a very small flat bit screw driver then unscrew the 4 screws in the phone then use the small flat bit onc more to open the phone cover, then remove the silver button on each side of the phone, unclip the cable leading to the camera and also the clip connecting to the lcd once those are removed then replace the old screen with the new one.
Dec 22, 2007 | Motorola Mobility RAZR V3
Razr V3i charging problem
Hi V3 is very fragile and if you use the incompatible accessories, you can ruin their ports easily. One weak point of V3 Phone is the SIM card Port is not an opening flap like other GSM phone but using pin and spring Port style which is mean you have to push your SIM card in and use the SIM Card edge to push the pin down in order to contact with SIM metal area interface. But by pushing force is varied from users so too strong and too hurry will damage the pin. If one of the pins is damaged, when you slide the SIM card in, the contact is missing of one or two pins due to damaging of the pin cause the error message "Insert SIM". In this case, only way is needed to replace the SIM Board underneath. If you can do it yourself, please follow the instruction pictures below. If you are not sure and never do this before, I suggest you send the unit to Motorola Repair Center. Your SIM Card Board and charging port will need to be replaced. http://www.itsjustmerob.com/files/V3_Razr-repair.pdf This is a Full Motorola V3 Officially Service Manual and even the Motorola Repair Center also has this one. so copy this link and print it out. Around hundreds plus pages but can be your Guide which you cannot find anywhere else. I gave it to you free but I have purchased it before. Hope that you can get it fix. Other solution is looking V3 parts on sale a lot on Ebay and use them to replace part to your phone will be cheaper if your phone is no longer under warranty. If it is still under cover then send the unit to them and don't spend time and money to do it yourself. But if it is out of warranty and want to avoid costly repair then use the method in the manual I provided you and you will be able to get your phone fix. Good Luck
May 13, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
27 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
