You should uninstall audio drivers then install the updated drivers for your audio.
then un-install iTunes and its all apple product using revo un-installer. that will ask to remove all the registry so while uninstalling the programme select all and delete them.
then download and install latest iTunes.
it will start working.
if it doesn't you can restore your computer to a previous date on which your itunes was working properly.
to do so.
click on Start >>>All Programms>>> Accessories>>System Tools>> System Restore>> Select the Date and Restore your Computer.
Enjoy!!
FIRST try the simple solutions. Check if your speaker wires are plugged into the proper ports.
If you are unsure, it won't hurt to try different configurations.
(If you hear sound from other devises such as plating a CD of the "Microsoft Sound" when starting up or shutting down, then the speakers are wired correctly.)
If this is OK then try...
Go to your "Device Manager" (Right click on 'My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Sound video and game controllers"). If there is some kind of a "Warning" icon superimposed on the 'speaker' icon there is your problem!
If no "Warning" icons then try...
One at a time...
Double click on each of the devises that have 'Audio' in the listings.
Click the "Properties" tab, look for any "Warning" icons
Uninstall the DRIVERS for THAT DEVICE only. See instructions below.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
