Question about Dell Dimension 2400 PC Desktop
Dell Dimension 2400 won't turn on
My Dell wont turn on.  The button on the front of the tower will turn red for a very short time when I push it, but the computer won't come on.  The monitor works fine and I've tried a different cord and tested the outlet the tower is plugged into.  Someone told me to buy a new power supply, but I think it might just be the button on the front of the tower.  I pulled the unit apart and carefully dusted everything and cleaned the contact point where is the button hits the switch on the inside.  Is there a way I can test the button, or should I just buy a new power supply?  Any help you can offer would be appreciated.  Thank you
  • 1 more comment
  • ricx Dec 22, 2008
    Dell XW8200 Server. Fans inop front panel red light blinks 3 times on power up. No DC voltage present on PS adapters. Replaced PS problem remains. Suspect Grounding or PS return problem but cannot confirm.
  • moregain Apr 14, 2009
    My Dell PC won't turn on, power light is amber and monitor dose work on other PC. What do I do now?
  • lucksboy6_9 May 11, 2010
    Before you do this, locate the A B C D lights in the back of your computer. When you try to turn on the computer please let us know if any or all light up druing that short period.
    Problem Solver:
  • 6 Answers
Replace the fuse
Posted on Sep 23, 2008
Have a ?, my dell 2400 seris turn on whn power supply is plugd in but none on screen. on front panel HD lite is on but nt power lite??? wats the problem?
Posted on Sep 22, 2011
  • 3940 Answers
SOURCE: optiplex 170l motherboard to fit
Both systems use a Mitac Chassis, only real difference is the front bezel.
So one motherboard should fit the other.
Posted on Jun 23, 2008
ghouliass
  • 105 Answers
SOURCE: trying to get wifi for Dell Dimension 2400
Less expensive for recieving is simply the "usb stick" I would recommand a "ralink" chipset, (can be found in USROBOTICS and some less expensive brand like TOPLINK
Posted on Nov 26, 2008
  • 11 Answers
SOURCE: lost my manual and need a illustration of tower
http://www.fixya.com/support/p349042-dell_dimension_2400_pc_desktop/manual-14417/page-9
Posted on Sep 28, 2009
RonPark
  • 855 Answers
SOURCE: how do you open the tower of a dimension 2400
If you look at the CPU from the back. On one side usually the left you will see a screw where the side wraps around the back. Some brands will use two screws. Remove this screw and then you can slide the side panel back toward yourself. Then you can turn the CPU exposing the open side. While your in there (make sure the unit is not plugged in) take a can of compressed air and clean your cooling fans and vents. Keeping a computer cool is important to keeping good performance up to where it should be.
Posted on Sep 30, 2009
  • 47 Answers
SOURCE: My Dell dimension 2400 monitor doesn't work when
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
Posted on May 28, 2010
Monitor turned on before at system startup with power button on tower now it does not
check whether the power on your monitor is turned on, check power connections from power source to see if it hasn't pulled out slightly... make sure they're all pushed in properly
Jun 20, 2012 | Dell Dimension 2400 PC Desktop
The 3 and 4 are lit up on the front of my dell desktop. the computer turns on but wont start.Also once it is on it wont turn off by pushing the power button, I have to unplug it. please help
Open up your tower and take out the ram. Then put it back in and close the case. Make sure your power cord is disconnected when you do it. Then restart and see if it helps.
Mar 12, 2011 | Dell Dimension E520 PC Desktop
When pushing the power button on the tower, the power lights on the tower, mouse, and keyboard continually flash, and the computer does not actually turn on. The only way for the flashing to stop is by...
The power supply is receiving power from the source but is unable to properly distribute it to the components. This means that either your power supply is bad or the motherboard. Try removing all devices attached to your computer and check your USB ports to see if they are damaged.
Jan 09, 2011 | Dell Dimension 2400 PC Desktop
How to remove computer cover
Try this website..this is a manual for Dell Dimension 2400 PC Desktop
it includes how to remove the cover of your tower. Check it out..
http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf
Sep 14, 2010 | Dell Dimension 2400 PC Desktop
I NEED HELP IN REPAIRING THE FRONT HEADPHONE JACK ON THE TOWER, AND WOULD LIKE TO HAVE ACCESS TO THE SHOP REPAIR MANUAL. DELL DIMENSION 2400 DESK TOP PC, THANK YOU AND KINDLY APPRECIATED !!!
You can just remove and replace the front I/o panel rather than repairing it . The part is not more than 10$. You can get the part from the following site
http://www.txcesssurplus.com/servlet/the-5850/Dell-Dimension-2400-4600/Detail
or
http://www.impactcomputers.com/d0971.html
How to remove the front panel
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/fpanel.htm
Thanks for using fixya
Proton
Aug 20, 2010 | Dell Dimension 2400 PC Desktop
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
May 28, 2010 | Dell Dimension 2400 PC Desktop
My dell dimension 2400 goes on standby automatically.
If the power LED on the Tower is blinking amber, then most likely the power supply in the tower is failing. Replace the power supply.
Dec 31, 2009 | Dell Dimension 2400 PC Desktop
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Contrast 100 window keeps appearing on screen
try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
1,083 people viewed this question
Alun Cox
