Question about Toshiba MD20FN3 20 in. TV/DVD Combo
No sound on only two channels (6 & 55)
All other channels are normal. Picture is good on channels 6 and 55 but no sound. There is sound when viewing through connected VCR tuner but not when viewing through TV tuner. Any ideas?
I'm stoopid. I pressed the Audio button on the remote control and discovered that the selection was set to SAP however no secondary audio was present resulting in no audio. It's no my TV so I am unfamiliar with the remote functions.
Thanks
Posted on Sep 01, 2008
Black screen
Possible causes
  • Your TV is not receiving or displaying the signal from your DIRECTV® Receiver.
  • Your receiver has correct guide information, but is not processing video correctly.
  • You are viewing a channel where an upcoming sporting or special event is scheduled or has recently ended.
Solutions
  • Turn TV off and on.
  • Make sure light on front panel of receiver is lit.
  • Press the "TV/DSS" button on the remote control or front panel of the receiver (not all receivers have this option).
  • Reset the receiver by unplugging the power cord for 15 seconds.
  • Check all cable connections between the dish, receiver and TV.
If the picture is black, but the program title and description display in a banner the top of the screen:
  • If the problem is only occurring on a few channels, check the detailed description of the program through the on–screen guide on those channels. Often, we display a blank screen with a banner before and after a high–profile event to alert customers about the event.
  • Reset the receiver by turning off and unplugging the power cord for 15 seconds.
  • Run a signal meter test to check your signal strength (press "menu" and look under "setup" or "installation").
If your signal strength is below 70 (or below 60 on HD receivers) in clear weather on transponders 1 and 2, see our troubleshooting steps for "Searching for satellite signal. Please stand by." You may see zero strength on transponders 4, 12, 18, 20, 26 and 28. This is normal in many areas. Your system manual shows how to run cables and point your dish.
Oct 24, 2007 | Toshiba 30HF66 30" TV
Model #_LT52152, when turn on TV no sound, sometimes picture frozen and sometime cannot change channel. Help!
Sounds like a firmware corruption. Contact the authorized service centre for Mitsubishi. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Mitsubishi LT-52151 52 in. LCD HDTV
Hd channels need to adjust stretch and normal view
That usually is an adjustment made on whatever source you have hooked to the tv. Some tv models will minuliplate the picture but not all.
Feb 04, 2014 | LG 47LG70 42 in. LCD TV
I am having a problem with my new vizio tv. I am
Try this solution....
1) On the original TV remote press the menu button.
2) Scroll down to SETUP and press MENU button to select it.
3) Scroll down to WIDE
4) Use the LEFT and RIGHT arrow keys to adjust to your viewing preference.
**** NOTE: When you adjust these settings you may notice a difference in the picture on the HD channels. When you are viewing an HD channel but the network is not broadcasting that show in HD they push in the sides to compensate and try to make it a sharper picture but know this is normal.
Good Luck and please rate this solution....
Jan 10, 2010 | Vizio VF550M 55 in. LCD HDTV
My tv got no sound..but if connect a video/dvd via rca ok.
Sounds like you have a tuner or an antenna problem. If you are using a DVT converter box to watch off the air TV, the signal has to be very good to get sound and picture. Try connecting a VCR or a DVD player trough the coax cable and see if it you get sound an pic on Channel 3 or 4. If you do, it is an antenna problem.
Nov 30, 2009 | Televison & Video
No picture on dvd but picture on tv only sound comes out on dvd
Could you try to set your channel to 2,3, or 5 when viewing video from dvd. Or try search which channel will the video and audio will sync in tune. I think this is an old tv.
Hope this one helps.
Apr 07, 2009 | JVC AV-27530 27" TV
''Hotel'' Viewing mode on Akai TV Model #CTS2550
Did you get an owners manual with the television?
Jul 01, 2017 | Akai CTS2550 25" TV
No signal
That sounds about right my friend. Those sets do have two tuners and Ive seen the problem your desribing. Unless of course that the microprocessor and tuning circuits are goos also. I would call a servicer if I were you unless yopu know your way around the inside of the tv set as it does have alot of High voltage even when its unplugged Good Luck
Jun 07, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Toshiba MD20FN3 20 in. TV/DVD Combo Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
