Question about LG CHOCOLATE VX8500 Cellular Phone
"Downloading Telus now"
My hpone got left outside and it rained, the sound worked but the screen was very wet on the inside. A friends reccomended that I put the phone in a bowl of rice because it will absorb the water, sure enough, it did! Now the phone will turn on, but once it gets to my regular screen it turns white and says "downloading telus now" it stays like that for awhile and then just shuts off. I would love to know if it is possible to fix this! thanks!
    Champion:
  • 221 Answers
Seems to be a internal phone problem. Your phone is booting into the telus bootloader. Take it to the telus store and they will replace it
Posted on Aug 25, 2008
Stupidly but accidentally left my Canon PowerShot SD800IS outside on table and it rained!!! I can't see anything through the screen! Stick seems OK. Battery is functioning. What can be done. Thanks.
Well you can try not to turn it on and let it dry out in a DRY room
But if you turn it on after it was still wet or it was not fully dried ...Then
you have to bring it to a camera repair shop I would call around but
make sure that you do not tell them it was wet because it they may tell you that
there is more problems then just the LCD screen.... So if the board is wet and
there was power turn on there will be clear signs of the residue left from the rain...
You can also call Canon to see if they no of any Camera Shops in your area that will Repair
it or Maybe give you a trade in credit towards a used or new camera,
Thank You
Jayson
Sep 15, 2008 | Canon Cameras
My 2002 Toyota Celica fogs up and collects moisture on the windshield during or after a rain. Visibility is a major problem. Need help, this is truly unsafe.
Can be that your heater core or hose inside car is sometimes releasing alittle heat at the clamps. So long the inside of the floor is not wet or damp or car is not over heating. I would not worry about the heater to much inside unless this does not work...
Change the automatic climate control up or down to cooler or warmer i usually run it at least upto 10 or 20 degrees different than the outside anytime i drive mainly during rain or snow.. So if outside it is warmer means you need to be cooler and cooler means get warmer. Also If you don"t run that on a regular basis a quick Ac on and defroster front and back works well and generally fast.I really think that is all of your problem just get comfortable with your automatic climate setting. once in a while it may happen again only because of rapid temp. changing from outside air to inside air in your car..Rain X works really well for a couple weeks between apps.and saves wiperblades during raining times. Always drive safely and good luck 11_21_2011_5_34_27_pm.jpg
Aug 16, 2011 | 2002 Toyota Celica
My jandy pda (pool remote) got wet inside, kids left out in rain and water must have got in behind controls now it does not turn on. What can I do?
Were you ever able to repair it? Our kids recently left our remote outside as well; and am looking for ways to fix it. Thanks!
May 07, 2011 | Sport & Outdoor - Others
Everytime it rains hard my carpet is wet by the door on the driver side and also driver side rear door
There is a great possibilty that there is a leak on the Left Side of the Windshield. It is most likely in the area of the upper left side.
The reason for this conclusion is:
The rain water is coming in the Left Upper Side; and either coming down the "A" Pillar, or traveling underneath the trim on the inside roof and coming down the "B" Pillar.
The only other explanantion is a torn, worn, cracked or dislocated Weather Seal on one or both of the doors, allowing rain water to come in. Inspect very carefully these Weather Seals, especially on the top front portion of the rear door.
To help you locate these after a hard rain:
Take the trim panels off the "A: and "B" Pillars and the Roof Line above both Doors. Check for wetness underneath the trim. Or take these trim panels off, and place folded paper towels under the trim panels; reattach the trim panels and wait until it rains. Afterwhich, take these trim panel off and check the paper towels for wetness.
The Windshield Seal is easily inspected for cracks and tears.
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Feb 12, 2010 | 2005 Chevrolet Colorado
1997 Toyota Camry LE. During wet weather, water
Most of the problems come when its raining and if its not being driven and water still comes in then its the bonnet rubber and if when its being driven then its due to the rear wheel throughing up water under wheelarch and somewhere theres a crack in the weld or somewhere and it will find its way in..
So if not using it clean it out and when rain stops look inside no rain no leak Have a goodday
Oct 09, 2009 | 1997 Toyota Camry
It rains in my car and my gas gauge stays on full
for the car getting wet prob check the plactic around the bottom of ur windshield on th outside of the car if this is cracked it make ur car wet
Apr 01, 2009 | 1991 Buick Riviera
White Screen
I would suggest Ebay.ca to find a used or refurbished phone. Make sure the phone is from Telus, because if it isn't it will likely not work with your service.
Aug 17, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Wet ds
try taking the battery cover off and removing the battery, placing all of the items, including any games that was in the console when you left it outside, in a facecoth or light teatowel, Put all the items inside a airing cupboard, or on top of a radiator, for a couple of weeks, to see if you can dry it out.
Do not put the unit dirtectly on top of a radiator. you must place it inside a teatowel or a facecloth. this worked for me but cannot say it will work for yours.
Nov 10, 2007 | Nintendo DS Lite Console
Cordless phone left outside in rain
there is a small transistor that drive the power maybe is short but nowk how to use a vom?...you will need it..just follow the circuit from the batery..good luck
Jul 27, 2006 | Panasonic KX-TG5571M Cordless Phone...
LG CHOCOLATE VX8500 Cellular Phone Logo
108 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
