Question about Nikon Coolpix 3500 Digital Camera
Why can't I access Shooting Menus? - Nikon Coolpix 3500 Digital Camera
    Novelist:
    Scholar:
  • 79 Answers
The Shooting Menus allow the user to control many aspects of the operation of the digital camera. You can change image size and compression, exposure compensation, sharpening, etc. When using a "Scene Mode" (Fireworks, Museum, Beach/Snow, etc)the camera determines the best settings for the particular scene and the options are limited in the Shooting Menus. If the Shooting Menu contains fewer options than expected or you are unable to adjust a particular setting be sure that the camera is not set in a scene mode. Depending on the camera model you should use "A" or "M" mode for full control.
Posted on Aug 30, 2005
SOURCE:
Factory reset
In camera settings menu, on the bottom of the screen you find Settings. In Settings is the only reset the camera knows. You only will reset the menus and shooting options. Date, time, language and video output settings are not reset.
If your camera has serious trouble, accessing menus or something like that, there is nothing like pressing a button for several seconds and everything will be ok. (not in the manual)
Dec 08, 2013 | Samsung ES30 Digital Camera
I want to put a password at my lexmark printer could that be done.
The User guide has all the information you need to perform thsi action.
Setting Password Protect for the menus
Apply an administrative password to restrict unauthorized users from making changes to the MFP configuration from either the control panel or the Embedded Web Server (EWS).
1 Touch the Menus button on the home screen.
2 Touch Settings.
3 Touch the down arrow and then touch Security.
4 Touch the down arrow and then touch Create/Change Passwords --> Create/Change Advanced Password.
5 Enter and reenter a password of both alphabetic and non-alphabetic characters. The password must be a minimum of 8 characters.
6 Touch Submit.
7 Touch Settings --> Security --> Password Protect to view what configuration settings are protected by the
Advanced Password.
Note: Settings --> Security --> Password Protect and Settings --> Security --> Create/Change Passwords --> Create Change user Password can be used to restrict access with a different password than the Advanced Password. Use Settings --> Security --> Password Protect to select the menus that are accessible with both an Advanced Password and a User Password.
Note: The Advanced Password and the User Password protect the menus on the touch screen control panel of the MFP and the Configuration section of the EWS pages.
Restricting Function Access
The MFP supports a variety of methods for authenticating users prior to allowing access to functions.
1 Open a Web browser. In the address line, enter the IP address of the MFP being configured using this format:
http://ip_address/.
2 Click Configuration.
3 Under Other Settings, click Security.
d Select an authentication method.
e Click Submit.
4 Click on the setup link for the authentication method previously selected in step d.
a Fill out the appropriate information for the environment.
b Click Submit.
5 Click Function Access.
a Set the function authentication level for each function. Select Off to prevent anyone from using a function.
b Click Submit.
Preventing access to the menus from the control panel
It is possible to prevent access to all the menus using the control panel touch screen. To prevent access:
2 Touch Settings.
3 Touch the down arrow.
4 Touch Security --> Function Access --> Menus --> Disabled.
5 Touch Submit.
Apr 16, 2013 | Lexmarkr X646E Multifunction Printer -...
Monitor screen can not appear photos before shooting
That's the way the D40 works. The monitor is for menus and picture review, not to show images before shooting. Nikon introduced the LiveView capablitily with the D3 and the D300, introduced after the D40. The D40 works as SLRs have worked for half a century, giving you the image through the viewfinder.
Nov 27, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Access to Photos on internal memory
The Copy command is in the playback menu. See the "Using Playback Menu" section of the manual (begins on page 75 in my copy). If you need a manual, you may download a copy here.
Jul 12, 2009 | Fuji FinePix Z10fd Digital Camera
Cannot select "camera menu" from the Top Menu
If the camera is in Auto mode those items cannot be selected because the camera is already using factory default settings and they cannot be changed, If you press the Ok button and change to P mode then you will be able to access all of those menu settings and make any changes you wish to the camera settings.
Dec 28, 2008 | Olympus Stylus 850SW Digital Camera
Sequential shooting modes
There are four sequential modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the CAMERA menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: - Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. - High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. - AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. - Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Aug 30, 2005 | Nikon Coolpix 2500 Digital Camera
Nikon Coolpix 3500 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
