Question about Sony VAIO R505JL Notebook
Dell latitude won't start
Dear,
My laptop does not start at all even with or with the power adapter, could you help plesase.
    Problem Solver:
  • 4 Answers
It is possible that the motheboard has gone bad.  The power brick could also have developed a short in the cable.  I would first see if you could use a different porwe cable and try that.  If that doesn't work, then i would suggest changing the motherboard if possible.
Posted on Feb 04, 2009
Dell D620 laptop screen won't come on after disconnect from docking station
please use the following small secret. Disconnect the power adapter from the laptop.
2) Dissasembly the batteries from the laptop.
3) press the power button in ON with the adapter+battery disconnected from the computer. and maintain press the power button by EXACTLY 60 seconds.This liberate the ESD.
4) Try again.
God bless you
Mar 05, 2013 | Dell Latitude D600 Notebook
My dell latitude d510 cpu fan won't start when i turn it on
sound like a faulty fan or the fan's power lead check all connections soldering and plugs for secure dust free connections or replace the fan
hope this helps
Oct 09, 2012 | Dell Latitude D510 Notebook
Dell latitude runs but does not boot up
Remove battery + power cord from AC adapter. Wait 10 minutes. Plug in only the power cord. Power-on the laptop.
If laptop starts correctly, plug in battery while it is up using the adapter. Leave on for battery to recharge.
Oct 19, 2011 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
My Dell Latitude D160 won't respond at all. I have to constantly push the power on button to even get it to come on and when it does, the battery light is on red and I think it says low critical power...
I'm confused too... it sounds like the power adapter is not (electrically) connecting to the laptop or the adapter is not delivering proper voltage/amps to the laptop.
You shoud 1. make sure that the AC plug is properly in the AC socket, 2. that the AC cord is (mechanically) connected to the adapter, and 3. that the adapter is (mechanically) connected to the laptop.
I cannot tell you how many laptops I have seen where the (internal) power connector breaks as a result of (typically) mis-handling, dropping, etc. Try (gently) wiggling the adapter connector and look for the LED changing colors.
You could also test the voltage output of the adapter with a standard Volt meter...
Sep 13, 2011 | Dell Latitude D610 Notebook
My Dell Latitude D810 won't even start up. All I have is the bluetooth light. Can you please help?
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 11, 2010 | Dell Latitude D810 Notebook
Dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
May 13, 2010 | Dell Latitude 100L Notebook
Dell Latitude 505 that will not run on AC
Sounds like a BAD adapter. When was the last time it worked in the laptop?? I would try another adapter if possible. When was the last time the adapter work on the laptop?
Jun 03, 2009 | Dell Latitude D505 Notebook
Latitude d520 will not recognize power adapter
I have heard about this problem with a number of Dell laptops, including the Inspiron models. The problem is that the connector for the power port may have been loosened after many years of use. This may require service from Dell on the motherboard.
Jan 15, 2009 | Dell Latitude D520 Notebook
Dell latitude D 610 battery dead
dell latitude batteries have a built-in battery life indicator on it. Press the button to see how much charge is left or if there's no charge at all. It sounds like your power adapter isn't charging
your battery. visit: http://accessories.us.dell.com/sna/batteryconfig.aspx?c=us&cs=19&l=en&manufact=694&s=dhs&stype=4&family=Latitude%20Laptops and choose the model of your latitude laptop.
u can get it cheaper on ebay or any 3rd party vendor. hope this helps.
Jun 16, 2008 | Dell Computers & Internet
Sony VAIO R505JL Notebook Logo
64 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
